Dyna rear tire change and axle reversal
I have a 2015 Street Bob and will be changing the rear tire soon. To get the rear axle out I see some people unbolt rear shock bottoms to lower the swing arm and others remove the muffler. I was reading some people reverse the axle when they re install the tire so the nut is on the right side so next time they do not have to move anything out of the way to get the axle out. My question is if you do reverse the axle how to you torque the axle nut there will be no clearance on the right side to get the socket on. Do you hold a wrench on the nut and place the torque wrench on the bolt head? It's a hollow axle and if done that way I don't think it would torque correctly. Any thoughts / info?
I jacked mine up and dropped shocks several times, I finally reversed my axle because I"m running a V&H MR 2-1, and was getting tired of unbolting the shocks.
Now, however, I'm back to unbolting shocks and jacking the bike.. I also have to remove the rear brake, to get my 'not stock on my bike' wheel/rim off.
Small price to pay, whichever way you need to go.
Received 2,189 Likes
Received 5,388 Likes
,then you need to be confident with what you do.
Proper torque is important,, but that doesn't mean you always have to have a tool go "click" when you've reached that point.
Get it?
Bigbender
01-23-2006 10:13 PM
