Primary Drive Locking Tool
Old Aug 5, 2017 | 06:35 PM
grumpy56's Avatar
grumpy56
Default Primary Drive Locking Tool
Why does Harley (in their service manual) say not to use the plastic wedge/step tool to lock the primary for service? Thanks.
Old Aug 6, 2017 | 07:04 AM
Nickd2689's Avatar
Nickd2689
I'd guess that plastic wouldn't last long. The clutch/compensator torque specs are pretty high so i don't think it would hold up.
Old Aug 6, 2017 | 07:22 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
On certain models the motor company cautions not to use the wedge because it will put too much stress on the inner primary cover, causing it to move.
Don`t ignore this warning.
Some models do not have dowel pins between the inner primary cover and the transmission case, 2006 Dyna had a lot of issues with inner primary cover to transmission case alignment.
Old Aug 6, 2017 | 07:33 AM
Notgrownup's Avatar
Notgrownup
Also can put undue pressure on the bearings, the lock bar is wY better
Old Aug 6, 2017 | 07:54 AM
MadMouser's Avatar
MadMouser
This recently happened to one forum member:
https://www.hdforums.com/forum/dyna-...ewed-am-i.html
Old Aug 6, 2017 | 08:35 AM
grumpy56's Avatar
grumpy56
YIKES!!!! Glad I asked!!! Can anyone recommend a good lock bar? I've used a piece of wood in my past, but if there is a good strong locking tool out there would like to get one. Thanks.
Old Aug 6, 2017 | 08:53 AM
TSheff's Avatar
TSheff
Yea I ordered a lock bar, waited for it, only to be the wrong one. Used wood again.
Old Aug 6, 2017 | 08:57 AM
golfblues's Avatar
golfblues
I just cut a 1" wide, 1/4" thick piece of iron to the proper length. Works great.
Old Aug 6, 2017 | 12:57 PM
Northbound Southerner's Avatar
I used an old metal chisel. I filed the blade flat. Worked great.
Old Aug 6, 2017 | 01:31 PM
Imold's Avatar
Imold
That stepped plastic block works fine in the primary chain for those nuts, but not in the belt or wedged against the primary case.
