Turn Signal Relocation Kit Dyna Wide Glide
Old 10-18-2017, 12:14 PM
JU2012FXDWG's Avatar
JU2012FXDWG
JU2012FXDWG is offline
Default Turn Signal Relocation Kit Dyna Wide Glide
Good afternoon.
I have a 2102 FXDWG. With the quick detach sissy bar.
I purchased:
90369-06D Harley-Davidson® Leather Saddlebags | Bar & Shield® | Dyna®
68544-10 Harley-Davidson® Turn Signal Relocation Kit | Dyna Wide Glide®
Local dealer quoted me minimum $500 to install these items.
Is this something that can be DIY?
Do I need a motorcycle floor jack to do this?
Any videos available showing how it is done?
Thanks for your help.
Old 10-18-2017, 12:54 PM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,514 Likes on 2,134 Posts
Originally Posted by JU2012FXDWG
Good afternoon.
I purchased:
You can save $100 and get this: http://www.greatbikegear.com/index.php/dwgms.html
I had it on my Low Rider S - worked great. There are instructions on the page.
Either can definitely be DYI if you can turn a wrench. All you really need is to get the rear wheel off the ground to make life easier. A cheap scissor platform jack from amazon will do it. (use caution not to hit the oil pan).
Amazon Amazon
(there are probably cheaper ones out there) - there's also a video on making one out of 2x4's
And with that $600 you save you can return the HD bags and get top of the line leatherpros and still be ahead of the game by $300 or so...
https://leatherpros.com/retro-series...na-saddlebags/
Best bags made. Best quick disconnect as well.
Good luck!
JU2012FXDWG (10-18-2017)
Old 10-18-2017, 01:35 PM
Nickd2689's Avatar
Nickd2689
Nickd2689 is offline
Mchad gave you the best advice you could get. I'll second the great bike gear kit (I have it on my lrs) but I didn't Jack the bike up for my street Bob or my lrs.
This is is absolutely a diy job. If you need any help whatsoever, either post a thread or pm us. You can do it!!!
The whole job should take you about an hour if you're installing the bags too. Check out some you tube videos, you'll see this is an easy task
Old 10-18-2017, 01:45 PM
rossWG's Avatar
rossWG
rossWG is offline
Good afternoon.
I purchased:
the relocation kit you bought should be an easy hook up, not knowing the hourly rate, it is still some mark-up.
DIY or a mate with a both of wiring knowledge would indeed get you a lift and then some for free
i took the other relocation kit option to keep the side plate, and use the leatherpro's. They are great bags with second to none support.
Old 10-18-2017, 02:11 PM
Mchad's Avatar
Mchad
Mchad is offline
Love that paint.
Old 10-18-2017, 08:02 PM
ClifWideGlide's Avatar
ClifWideGlide
ClifWideGlide is offline
I would like to see a picture of the bike! A “2102” Wide Glide! Kidding aside, it shouldn’t be too hard if you have any mechanical and/or electrical ability. Can you solder the wiring? It’s easier with the bike jacked up as you will be working on the inside of the rear fender. On my1998 fxdwg I did the same, moved the turn signals and put saddle bags on. I didn’t have the option back then for detachable bags or sissy bar but I wanted to be able to remove the bags so I remodeled the HD design to where I can remove the bags as only 2 bolts hold each one on. If you do this yourself just take your time and think it through. Don’t rush and you should be ok.
Old 10-18-2017, 08:16 PM
Mchad's Avatar
Mchad
Mchad is offline
Shouldn’t need to solder. Connectors can easily be depin’d. Just take photos and make sure the right colors go back in the right spot. E-Z
Should be this connector.
Old 10-18-2017, 08:25 PM
JU2012FXDWG
I didn't catch the mistake! 2012.
What are your thoughts on this jack:
Old 10-18-2017, 08:30 PM
ClifWideGlide
Mine didn’t have those as my instructions and bags came with butt connectors but I soldered mine. I guess looking back on it I could have pulled the whole fender harness and de-pinned the main connector under my seat. My turn signals are hard wired.
Old 10-18-2017, 08:35 PM
JU2012FXDWG
Quick Reply: Turn Signal Relocation Kit Dyna Wide Glide
