Alternative Routing for EBS
Old 01-28-2018, 04:24 PM
crusader1xxx's Avatar
crusader1xxx
crusader1xxx is offline
Default Alternative Routing for EBS
Hello.
I recently replaced my AN Big Sucker for a DK Customs 606 AC set up including their stealth breather system.
I have seen a lot of posts about the EBS and what it does, and have always had a external system on my bikes. I was running the AN one as it seemed a good set up until I realized it was EPA compliant and ran the breather gases back into the AC unit.
So this weekend I did both my bikes using the DK set up. I was able to run the hoses under the tank, using the "Y" connector I ran a single hose under the seat. It makes for a real clean setup. Depending on how much the filter drips (if any) I might put a little cup under it with some shop towels just to soak up any extra gook that might come out.
I am quite pleased with the way it looks, very clean install with nothing really showing.
Close up of the stealth breather connector
The hose runs along the frame channel (zip tied to the wiring).
a little diagram to show how I routed it....
DK Custom - ST (01-29-2018)
Old 01-28-2018, 05:41 PM
rbdub474's Avatar
rbdub474
rbdub474 is offline
You might think about using a catch can with foam to absorb the oil as opposed to the filter in that location. Would keep it cleaner I’d imagine.
Old 01-28-2018, 07:16 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,039 Likes on 657 Posts
I would rethink that spot. Think of the water and gunk that's going to come out of it right there
TinCupChalice (01-29-2018)
Old 01-28-2018, 07:52 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
Yeah, what he said.
It's sometimes not about the amount of "oil" that slips through the filter,, but those gases are "hot" (when running), then they're cool (engine off),, then they're hot,,, then they're cool.
I plopped my filter in a "vented" catch can because I was worried too,, all I see or have found in that catch can is water.
You can figure it out now or later,,
Old 01-28-2018, 08:35 PM
crusader1xxx
Thanks for the comments guys, and I understand where you are coming from....these were what was supplied in the kit.
If I find there is an issue then I’ll look into a catch can, but really, my bike is a non puker.....so I think it will be fine.
Old 01-28-2018, 11:50 PM
Kraken's Avatar
Kraken
Kraken is offline
Non puker based on the breathers being routed back into the intake and not dripping from the intake filter? So was mine and that's definitely not the case with external breathers.
Old 01-29-2018, 05:02 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,750 Likes on 3,962 Posts
This right here, not a location I'd consider
Campy Roadie (01-29-2018)
Old 01-29-2018, 05:13 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,065 Likes on 2,501 Posts
What are you going to do when that hose becomes plugged with pooled water and oil blocking the vent?
The following 2 users liked this post by Campy Roadie:
rideon (01-29-2018), TinCupChalice (01-29-2018)
Old 01-29-2018, 12:02 PM
nevil's Avatar
nevil
nevil is online now
Leaving it there is just asking for a big mess that could be easily avoided.
Old 01-29-2018, 03:04 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
If I wasn't using breather bolts I'd weld a scavenging bung into the header(s) and dump into there.
strych9
Milwaukee Eight (M8)
26
04-30-2023 04:43 AM
Bowhunter8607
09-13-2020 09:42 AM
Rijan
04-02-2019 03:43 PM
DK Custom
14
03-07-2019 10:08 PM
Fblo1690
EVO
14
07-16-2018 05:46 PM
Quick Reply: Alternative Routing for EBS
