Won,t start. Need help.
Old Jul 11, 2018 | 05:33 PM
TxBulldude's Avatar
TxBulldude
Default Won,t start. Need help.
2005 fxdi super glide. Replaced the fuel filter, plugs and battery. Got it back together and now it is not starting. No fire to the plugs at all. Can you reset the ecm maybe? It did give a p1003 code before it took it apart. Don’t know what els to try.
Really need to get this bike running. Thanks.
Old Jul 11, 2018 | 05:39 PM
ClifWideGlide's Avatar
ClifWideGlide
Can you check your to see if your ignition coil has power, ground and a signal to fire?
Old Jul 11, 2018 | 06:22 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Does the engine turn over? Can you set the silent alarm using the center of the key FOB. Try a couple of cycles of turning on the alarm , turning off the alarm, my 05 FXDLI did that to me once.
Old Jul 11, 2018 | 06:52 PM
TxBulldude's Avatar
TxBulldude
No alarm on this one.
Old Jul 11, 2018 | 07:42 PM
TxBulldude's Avatar
TxBulldude
Engine turns over. Not seeing a spark to plug when I pulled one and grounded it. How would I check the coil for a signal? I can handle most of the mechanicle stuff but not so much the electrical. Again I thank you for any help..
Old Jul 11, 2018 | 08:32 PM
joe40x's Avatar
joe40x
Blown ECM fuse
Old Jul 11, 2018 | 10:07 PM
TxBulldude's Avatar
TxBulldude
Looked ok but replaced it anyway. Still no go.
Old Jul 12, 2018 | 11:38 AM
nevil's Avatar
nevil
You won't see a spark by removing the plug and grounding it. The ECM won't provide spark if there is no compression. You'll need an inline spark tester.
Old Jul 12, 2018 | 06:30 PM
Huggerbugger's Avatar
Huggerbugger
Remove one plug, put a 10-ga. shotgun shell in the hole (brass side out) and whack it with a hammer while it's turning over.
Old Jul 12, 2018 | 06:34 PM
TxBulldude's Avatar
TxBulldude
Have an in-line and am still seeing no spark. Checked the coil, I think. Get about 5k resistance between poles on the plug side. Get no resistance between any of the 4 posts on the other side. Not sure what that means.
