Installing apes on a 2012 Dyna
you should not have to de-pin a can-bus bike, the connectors are smaller and fit through the holes in bars. Older style Deutsch connectors will need to be de-pinned as those connectors are much larger. I belive the can-bus bikes started in 2012? i could be wrong. My 14 FXDL is can bus, no de-pinning required.
apes
you should not have to de-pin a can-bus bike, the connectors are smaller and fit through the holes in was bars. Older style Deutsch connectors will need to be de-pinned as those connectors are much larger. I belive the can-bus bikes started in 2012? i could be wrong. My 14 FXDL is can bus, no de-pinning required.
Thanks
