will not turn over
will not turn over
hello
I have a 2001 dyna wide glide I was working in the t/l and got a spark now I have no blinkers brake light and it will not turn over I found a blown fuse replaced that but still have the same problems were do I look next I do have lights and dash lights and horn
kevin
kevin
By t/l, do you mean tail light?
Where on the bike was the spark you saw? Was ignition On at the time?
Recheck all your fuses to see if any have blown again.
If blown, record the position of the fuse and see what circuit it is for. Some years of Dyna had a picture on inside of left side cover for identification.
hello
I was in the rear tail light and a wire pulled out of the pin the one for the main tail light when I was re inserting it a got the spark I ck ed the fuses found one blown replaced it and I have no blinkers on brake light and will not turn over the battery reads fine where would I find the ignition fuse also could the tsm have shorted
kevin
kevin
Received 4,314 Likes
JayStronghawk (02-24-2019)
iRider
Electrical/Lighting/Alarm
17
06-08-2015 07:28 AM
TReaper
11-18-2014 12:16 PM
