Corrosion resistant black bolts for engine
Old 03-15-2019, 01:44 PM
m1369x's Avatar
m1369x
m1369x is offline
On YouTube there's a site Dell Boys Garage He explains about burning used oil into bolts (the dirtier the oil the darker the bolt) I haven't tried it yet but it sounds good , I'm just curious about oil bleeding out over time and lock tite
Old 03-15-2019, 03:25 PM
M4dm4x's Avatar
M4dm4x
M4dm4x is offline
Originally Posted by bigal51
Spray the SS screws with any dry lube like a chain wax or even a little syn engine oil. Guarantee it won't gall in aluminum.
id be a little worried about bolts backing out with lube and no loctite, you ever have issues with that?
Old 03-15-2019, 03:27 PM
RhynoRocK's Avatar
RhynoRocK
RhynoRocK is offline
Doesn't ARP make black coated bolts? I'd hit them up, either on their site or somewhere like summit racing or jegs.
Old 03-15-2019, 03:28 PM
M4dm4x's Avatar
M4dm4x
M4dm4x is offline
im familiar with his channel, I’ll have to look into it. I’d be worried about them staying tight.
Old 03-15-2019, 03:31 PM
John CC's Avatar
John CC
John CC is offline
If you do it right, there's no oil to bleed out. Use old oil from a Diesel engine as it is loaded with carbon, which is what makes the part black. Don't over heat them or you'll change the temper of the part.
M4dm4x's Avatar
M4dm4x
M4dm4x is offline
they do , bu they are just black oxide and rust quickly.
Old 03-15-2019, 06:48 PM
fxdx1985's Avatar
fxdx1985
fxdx1985 is offline
Old 03-15-2019, 06:51 PM
fxdx1985's Avatar
fxdx1985
fxdx1985 is offline
All those screws/bolts in the dash have gloss nail polish on them. You can’t tell the different between the powder coated dash pieces and the nail polish. Gets you a black bolt for about $3 instead of spending hundreds on ARP. This stuff holds up forever too (though I’m not riding in snow).
Goobius (11-17-2021)
Old 03-15-2019, 11:55 PM
M4dm4x's Avatar
M4dm4x
M4dm4x is offline
looks good! I’m gonna give this or this or duracoat a try.
Old 03-16-2019, 12:46 AM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,993 Likes on 17,500 Posts
Black Oxide stainless steel hardware, won't come bike specific and you'll have to hunt up an online supplier like this place, or several others you just have to hunt a bit.
https://www.fastener-express.com/
They are durable and look powder painted, I've used them before..
Quick Reply: Corrosion resistant black bolts for engine
