Strange noise recently
Over the past month or so i've been hearing this strange scraping metal on metal sound when going over speed bumps, potholes, pretty much any kind of transition. I went around and torque checked every bolt i could see and nothing seems loose. I'm pretty confident it still has the original motor mounts but to my eyes (at least the front one) isn't sagging at all. Could that be it? I've heard guys talk about excessive vibration and death wobble from bad mounts, but i'm not experiencing either of those. Any other ideas or things I need to look at?
It’s really weird to describe.. Have you ever ridden in an old car that the struts are completely obliterated? That creaking sorta rattling sound you hear right before the big clunk. That’s what it sounds like, minus the clunk.
I don’t think the rear shocks are worn. They’re practically new LRS shocks. I’ll take a closer look at the mounts today.
Swing arm pivot? Can you duplicate it by bouncing on the seat off the jiffy?
I guess you could rule out the suspension by going slowly over a speed bump to see if happens when the front or rear compresses?
Shot in the dark.....A buddy of mine had a weak jiffy spring and it would swing down and hit/scrape when he would go over speed bumps or pulling into driveways.
