Tank Emblem Removal Problem.
Old Jul 28, 2007 | 11:34 AM
Cornhusker's Avatar
Cornhusker
Default Tank Emblem Removal Problem.
with my 07 Streetbob. Heated emblems and they came right off in seconds but left the complete script in rubber. I have been removing the rubber from both side using the hair drier but it's impossible to peel it all off and there is too much residue rubber. How can I get the residual rubber removed from the tank so I can remove the remaining adhesive???
Thanks for any help/advice.
Old Jul 28, 2007 | 01:27 PM
cravenc's Avatar
cravenc
Default RE: HELP!!!! Tank Emblem Removal Problem
3m makes an adheasive remover that worked for me, about $7 @ Advance Auto Parts.............
Old Jul 28, 2007 | 01:37 PM
jackyl's Avatar
jackyl
use wd40, works great. soak the adhesive with the wd40 on a rag. let it sit for about 5-10minutes, then soak a soft cloth with wd40 and slowly rub the adhesive. comes right off, thats how i took mine off, worked great. jackyl
Old Jul 28, 2007 | 02:15 PM
Cornhusker's Avatar
Cornhusker
ORIGINAL: cravenc
I was just at an auto parts store looking for that stuff and they didn't have ANY 3M products. Will hit Advance Auto Parts tomorrow. Don't have any problem getting the adhesive off, but with the rubber remaining on the tank, can't get the rubber off to get to the adhesive.
Old Jul 28, 2007 | 02:19 PM
Cornhusker's Avatar
Cornhusker
ORIGINAL: jackyl
Thanks Jackyl. I really like my tank lift!!
I don't have a problem with getting the adhesive off, it's the residual rubber on top that I wasn't able to completely remove that I need to get off so I can remove the adhesive...???
Old Jul 28, 2007 | 02:30 PM
NEONNIGHT34609's Avatar
NEONNIGHT34609
A++ this is what i used .. just remember to wash area/bike off when done .. especaily if its denim
ORIGINAL: jackyl
Old Jul 28, 2007 | 02:49 PM
Cornhusker's Avatar
Cornhusker
WD40 will remove the residual rubber??? I know it will take off the adhesive>
ORIGINAL: NEONNIGHT34609
ORIGINAL: jackyl
Old Jul 28, 2007 | 03:03 PM
Airborne350G's Avatar
Airborne350G
I use an eraser wheel to remove all the badges on my vehicles. Auto body shops use it to remove pin stripe tape also. Not sure how it would work on the textured denim finish though.
Old Jul 28, 2007 | 05:48 PM
firefighter3666's Avatar
firefighter3666
I can't help with removal for those with the denim paint..... but if you don't have a denim bike you can try RainX Bug and Tar remover. I used if to get the adhesive off the rear fender with I pulled the reflectors the other day. Just remember to wash and rinse well, and then rewax the affected area. Keep working at it, it'll come off.
Old Jul 28, 2007 | 05:55 PM
voyager1's Avatar
voyager1
mine was a very slow process even with heat... i just kept working the rubber junk off with my fingers. then like said before. wd-40.and goo-gone. then polish or wax area... opp's no wax withthe flat pait. skip that part . took me over 3 hours to do the job. my bike was over a year old. i think that makes it tougher to get off the junk .
