Gas Cap
Old Dec 17, 2020 | 08:25 PM
bulldog1776's Avatar
bulldog1776
Default Gas Cap
I have an 05 wide glide, so it has a fuel gauge on one side and a gas cap on the other side. Does it matter if I use a vented or non vented cap on this model of Harley?
Thanks guys.
Old Dec 17, 2020 | 08:35 PM
kel03's Avatar
kel03
See message below,
Old Dec 17, 2020 | 08:37 PM
bulldog1776
Originally Posted by kel03
Tank vented not the cap
Thanks, I'm looking at some aftermarket gas caps. So, can I use either one on my bike? Or non vented only?
Old Dec 17, 2020 | 08:41 PM
kel03's Avatar
kel03
I may have lead you wrong, wait till others chime in.
Old Dec 17, 2020 | 09:19 PM
Giver of Doom's Avatar
Giver of Doom
I have an 05 wide glide, my cap is vented. So, if you replace the cap, it has to be vented.
Old Dec 17, 2020 | 09:39 PM
hardheaded's Avatar
hardheaded
I thought after about 1992 the caps were no longer vented, they had a hose that ran from the right tank to under the bike to vent the tanks. My 92 had a little nipple that stuck up in the right side tank fill hole. At least that the way i remember it. I have the stock tanks for that bike still i will take a look at them.
Old Dec 17, 2020 | 09:46 PM
Giver of Doom
The cap is vented for suction, not pressure. The tank is vented from the vapor valve inside the tank to atmosphere.
Old Dec 18, 2020 | 12:12 PM
snake_eyes's Avatar
snake_eyes
Old Dec 19, 2020 | 04:18 AM
Bob_fxdb's Avatar
Bob_fxdb
...they had a hose that ran from the right tank to under the bike to vent the tanks.
Isn’t that to balance the fuel on both tanks on the older models and also on the new models?
And yes, you need the vented cap.
Old Dec 19, 2020 | 10:59 AM
GearheadMike's Avatar
GearheadMike
A vented gas cap is to allow air back into the tank as the fuel level goes down (on a tank with no other venting).
You can use a vented cap on a vented, or non vented, tank with no problem.
But if you use a NON vented cap on a NON vented tank, eventually it will 'vacuum' lock and quit running.
When in doubt, use the vented.
tomt
Dyna Parts
Dec 16, 2011 01:16 AM
Bacon_Grease
Feb 6, 2009 07:38 AM
mdxd62
Dec 9, 2007 05:15 PM
03Custom
Dec 9, 2007 01:03 PM
