How much brake fluid does 11/16th front brake master cylinder have
Old 06-05-2021, 10:38 PM
cycler's Avatar
cycler
cycler is offline
Default How much brake fluid does 11/16th front brake master cylinder have
I replaced my 11/16th front brake master cylinder with the Brembo 19RCS Corsa Corta. And to make it look 'Farkle" which my MC Bros call things ( they are actually making fun when they use the word Farkle) that are Functional and Sparkly I ordered this AEM reservoir that bolts right into the brake master cylinder to give it a clean look with no hoses or brackets https://www.motovationusa.com/integr...ab-description Its still on backorder for another 2 to 3 weeks. Im not sure exactly how many ML of brake fluid the AEM holds. But the unit itself is 42mm. From the looks of it I think it will hold enough or more than enough brake fluid. For now I was just going to order the clear plastic inexpensive Brembo plastic reservoir kit so I can ride ride the bike.
But I was just wondering. Can anyone tell me how many ML of brake fluid are in the OEM 11/16th brake master cylinder reservoir? I just want to sort of compare and see what each one has.
Raymond Loh
10-19-2023 07:51 AM
Raymond Loh
05-23-2021 07:16 PM
JMAY_ATL
Ironhead
09-29-2014 06:09 AM
lornalee58
Wheels/Tires
04-23-2009 02:11 PM
mdjim
04-16-2009 12:11 PM
Quick Reply: How much brake fluid does 11/16th front brake master cylinder have
