2000 dyna wide glide no fire
2000 dyna wide glide won’t fire. Installed new bars with wire extensions (did not remove battery) rookie move, I know. Brand new coil, cam shaft sensor is working properly, bank angle sensor is working, no pinch in the wires or nicks. Tested all fuses and relay. Im thinking it’s crank shaft sensor… is there any certain way to test it ? With a multimeter or test light ?thanks in advance, I just joined the forum
Tighten the battery connections and start from there. Don't just look at the connections actually put a wrench on them. Had a similar situation with my '99. Do you have a push start button on your starter? You may have a bad connection in the start switch. Also check for a grounded wire in your loom. Use your service manual's electrical diagram. Start at the battery, and work your way up. You'll find it.
