taillight/turn signal issues
Old Sep 27, 2021 | 04:05 PM
JC1966's Avatar
JC1966
Default taillight/turn signal issues
I was riding last week to work before daylight, and stopped at a redlight waiting, a cop was in next lane over and behind me, he blew his horn to kindly tell me my rear lights were not on...after getting home that evening I noticed also right turn signal does not work either...bought all new front and rear bulbs, as the right front right turn signal just glows brighter but does not blink....removing the rear tailight and brakelight assemble and opening it up I noticed mine has 3 wires from the turn lights on both sides, Blue, Violet and Black, but the Blue is cut way close on both coming out of the turn signals and there really is no place for them to go, as the plugin only has a 2 wire plug into the rear brake light assembly....violet and black....new bulbs still nothing, found a almost cut in half wire under the seat going back to the lights, fixed it and still the same, no lights and no right turn signal, ( left one has turn signal but no running lights come on....are there any fuses to check? if so where, I could not find and more bad wires . I am at a standstill on the rear lights..what should voltage be going to the bulbs inside 6 - 12 or what????
any suggestion as to what to check next? it had 1157 bulbs in both front and rear are those the correct ones?
Jeff
Old Sep 27, 2021 | 09:03 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The rear signals if original will only be a single filament bulb (turn signal only).
The front turn signals are dual filament bulbs(running light and turn signal).
What model and year bike are you working on?
Are there any aftermarket lighting parts on the bike?
Old Sep 28, 2021 | 02:40 PM
JC1966's Avatar
JC1966
its a '99 FXDWG so if the rear are a single filament, what bulbs should that be? the ones I took out were 1157 double..... but the rear should still be on as driving lights always or not???
Thanks
Jeff
Old Sep 28, 2021 | 05:08 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The rear signal lights are just that, turn signals, no running lights, single filament bulb, 1156.
The front are running lights and turn signals, 1157.
Old Sep 28, 2021 | 05:23 PM
Crazy's Avatar
Crazy
It sounds like someone has installed front turn signal housings on the rear of your bike. That explains the cut third wire. That also explains why there are 1157 bulbs back there and not 1156. 1157 and 1156 bulbs have a different pin arrangement, so you can't plug an 1157 bulb into an 1156 socket and vise versa.
Old Sep 28, 2021 | 08:56 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Ya gotta help yourself here. You don't know if it's a 6 or 12 volt electrical system. Get a Factory Shop Manual and look at the lighting wire diagrams so ya know what each wire does. Then trace down the wires. Here's a HINT . . . Violet normally is turn signal, black is ground and blue running light.
Old Sep 29, 2021 | 08:27 AM
xbeaus33's Avatar
xbeaus33
oh man - feel for ya. Been in the same boat. I ended up taking the seat and rear wheel off. Found all the wires and got my trusty test light and found out what the hell in tom foolery someone did. Once I familiarized myself with the mess it was pretty easy.
Old Sep 29, 2021 | 08:36 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Can't find 1999 but 2001 wiring diagram - https://serviceinfo.harley-davidson....ight=1999+dyna
It shows on page 43 the lights wired as Dan describes.
Old Sep 29, 2021 | 09:46 PM
Dave Sleyer's Avatar
Dave Sleyer
Default Custom accy fuse?
If the wire was cut and not capped it might just have blown the fuse. I had that problem before. I have an 09 fxdb it’s the cheapest and easiest fix so hopefully that’s it. On my bike the rear lights all go off the fuse labeled custom accy
Old Sep 29, 2021 | 09:47 PM
Dave Sleyer
Default Is your gauge cluster functioning?
Also when I blew that fuse the instrument panel worked intermittently so if that’s a problem too it’s probably just a fuse. Good luck
txphatboy
Electrical/Lighting/Alarm
Dec 29, 2016 01:51 AM
99XL883C
Dec 9, 2007 06:42 PM
aintgutno
Jun 25, 2007 11:03 AM
guild
General Topics/Tech Tips
May 22, 2007 03:07 PM
rocamotacoca
Feb 21, 2006 09:22 AM
