Adjustable pushrod question
Old Dec 28, 2021 | 07:04 AM
crzoomb's Avatar
crzoomb
Default Adjustable pushrod question
A coworkers brother did a cam swap on his ‘10 SG, never changed the cam bearings, didn’t have tool.
letting him borrow mine, here are my questions.
If the lifters are already primed do you still set zero lash the same and how many turns do you make on the pushrods( S&S quickies)?
To me it would seem that if the lifters are primed won’t that change the number of flats?
TIA !
Old Dec 28, 2021 | 08:27 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Always set pushrods to zero lash (zero lash is a just barely snug pushrods).. Then from there extend pushrods 4 full turns and lock it down... Here's a video, hope it helps..
And here's a chart for preloading the lifters based on pushrods TPI, threads per inch
https://images.app.goo.gl/aya8yhTYjbUKcjNi7
Old Dec 28, 2021 | 09:20 PM
Blue Bob's Avatar
Blue Bob
The lifters should be bled before adjusting lash. You are setting the zero lash against the internal springs in the lifter, then adjusting down to the center of the lifter travel.
Check your cam and lifter manufacturers recommendations before setting lash.
Old Dec 29, 2021 | 06:54 AM
crzoomb's Avatar
crzoomb
So the lifter does need to be bled down, great thanks !
Old Dec 29, 2021 | 07:13 AM
multihdrdr's Avatar
multihdrdr
The valve spring will bleed it for you
https://www.sscycle.com/tech-info/pushrod-adjustment
Old Dec 29, 2021 | 07:24 AM
98hotrodfatboy
Lifters usually come pumped up from whoever you bought them from.. You do not need to bleed them down to adjust them properly.. Always make sure the cylinder you are doing is at TDC. Start with a loose pushrod (short) then adjust the length longer till there is no gap or play in the pushrod as I showed in my video. Then adjust the preload on the lifter with 4 full turns. On the S$S pushrod with 32 TPI this would be .125". Most all stock or standard lifters have .200" of plunger travel. Anything less would be a limited travel lifter or a slow bleed race lifter.. It all depends on the manufacturer.. The method I'm describing is from the "top down" in other words the lifter plunger is all the way up because of the spring in the lifter body.. This method is fool proof and I believe the safest way for a first timer.. Once the proper adjustment is made wait till you can spin the pushrod before turning the motor over to do the other cylinder. It could take 10-15 minutes for the lifter to bleed down, this will ensure you did not set the preload to deep and possibly have valve to piston contact when turning the motor over to set the other cylinder.. I've done it this way for over 40 years on cars and bikes with Hydraulic lifters and never had an issue..
Antman57
2018+ Softail Models
Feb 23, 2023 04:55 AM
johnod
EVO
Feb 21, 2015 11:17 PM
harleyman1340
Apr 6, 2010 08:04 PM
jarhead45
Jul 29, 2009 10:19 PM
SpiderPig
Jan 10, 2009 07:31 PM
