Help please
Old 05-23-2023, 08:35 PM
Brandonberryman30's Avatar
Brandonberryman30
Brandonberryman30 is offline
Stage I
Default Help please
2006 dyna wide glide key on fuel pump primes up new coil new plugs new cps hit start button it will just crank if you let off the button and just keep clicking it fast and not hold it down it will start all connections seem good once’s it does start it runs fine nebee had this happen but you have to sit and just keep clicking the button it absolutely will not start if you hold it down anyone else ever had this issue if so what did you do to fix it
Old 05-24-2023, 07:54 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,814 Likes on 1,066 Posts
I experienced the same issue one time a few years ago. I just used a little bit of punctuation and that seemed to fix the problem.
The following 6 users liked this post by OldEnuf2NoBtr:
Cheekster (05-26-2023), crzoomb (05-28-2023), hattitude (05-27-2023), kel03 (05-26-2023), Mongo7 (05-24-2023), snake_eyes (05-24-2023) and 1 others liked this post. (Show less...)
Old 05-24-2023, 08:05 AM
Weeboy1's Avatar
Weeboy1
Weeboy1 is offline
Thanks for the morning laugh!
Old 05-24-2023, 09:19 AM
snake_eyes's Avatar
snake_eyes
snake_eyes is offline
Received 1,123 Likes on 665 Posts
Maybe it makes me a dick, but whatever. Why do these new guys come here and post word-vomit like that? It seems disrespectful.
Old 05-26-2023, 06:38 PM
Cheekster's Avatar
Cheekster
Cheekster is offline
Stage III
I laughed at 5:30 PM ...
Old 05-26-2023, 06:55 PM
kel03's Avatar
kel03
kel03 is offline
Received 6,045 Likes on 4,356 Posts
Prize goes to the first that reads it once and understands !
Old 05-26-2023, 07:42 PM
John CC's Avatar
John CC
John CC is offline
I suggest you try to figure out why the ignition doesn't fire until you let off the starter button...
The easier it is for folks to figure out what you're trying to say, the more likely you'll get a good answer.
Old 05-26-2023, 10:03 PM
TexasScooterTrash's Avatar
TexasScooterTrash
TexasScooterTrash is offline
Received 1,231 Likes on 757 Posts
I'll try to explain what is going on in laymans terms the fluxcapacitor has malfunctioned this is probably due to the change to daylight savings time which expotntionally changes the polarity of the fluxcapacitior unfortunately it can not be reversed once it's polarity has reversed so you now have a seasonal motorcycle that will only start normally by pressing and holding the starter button in until the engine starts on standard time as for a fix to correct the current situation I would suggest you check the handlebar control starter button with a multimeter to make sure the button contacts are not burned up from all the arcing going on inside of the switch be sure to also check the starter relay in the rare event that the starter switch or starter relay is bad you can simply ignore the fluxcapacitor.
Old 05-26-2023, 10:20 PM
Weeboy1's Avatar
Weeboy1
Weeboy1 is offline
Does that mean TST gets the “Prize”?
Old 05-27-2023, 01:14 PM
John CC's Avatar
John CC
John CC is offline
Not me. I read it at least twice.
Quick Reply: Help please
