Super E bending me over. Not spraying gas.
Old Aug 20, 2023 | 10:00 PM
s8nw8n's Avatar
s8nw8n
Default Super E bending me over. Not spraying gas.
I have a 94 fxdwg I just rebuilt the carb on (S&S Super E) and when I first got it back together, it would spray gas when twisting the throttle. I took it back apart to make sure I adjusted my float correct, and now it will not spray out. I have checked everything to ensure it’s clear. I’m stumped.
Old Aug 20, 2023 | 11:29 PM
springers4ever's Avatar
springers4ever
Cool Accel Pump....
We think you are talking about the accelerator pump that works to shoot gas in the carb at start up and when applying full throttle ...???
if so ...you need to turn the adjustment screw for the pump.(the one down by the front intake runner ) (which is a flat head screw head ) all the way in, and make 1/4 turns out till you see fuel...
turning it all the way to the right will shut the pump off ...and should only be used for starting and turned off when jetting the carb ...
Old Aug 21, 2023 | 12:16 AM
s8nw8n's Avatar
s8nw8n
What if adjusting that screw doesn’t spray gas and I’ve cleaned the spray nozzle
Old Aug 21, 2023 | 08:01 AM
misfitJason's Avatar
misfitJason
Do you have the petcock turned on?
Old Aug 21, 2023 | 08:39 AM
TexasScooterTrash's Avatar
TexasScooterTrash
There are small O rings used the the bowl for the pump. If ya lost one or did not put the pump rod back in, it won't pump fuel in. Go back over yer "rebuild" cause ya missed something.
Old Aug 21, 2023 | 08:55 PM
Max Headflow's Avatar
Max Headflow
Did you lose the pushrod that pumps presses on the pump diaphragm?
Did you disassemble the pump and loose one of the *****?
Old Aug 22, 2023 | 12:17 AM
98hotrodfatboy's Avatar
98hotrodfatboy
That's what I'm thinking one of the check ***** are missing not assembled correctly..
Old Aug 22, 2023 | 09:08 AM
misfitJason
We need pictures!
Old Aug 22, 2023 | 09:29 AM
s8nw8n's Avatar
s8nw8n
I’ll get it back apart this week and get pics up. I didn’t lose the 2 ***** or the small spring. I got the S&S rebuild kit and replaced everything exactly. The rod is new and the plunger is new. Same with the boot on top by the adjuster screw. At first it sprayed gas, then I adjusted it to the specs of the S&S video and since I’ve had no gas. The bowls got it in there, the sprayer is clear (air passes thru). I figured it’s a mixture of the adjuster screws. I just screwed the accelerator pump screw all the way in and 1/4 turned it out as I twisted throttle to check for spray, and NOTHIN. Got all the way out with no spraying.
Old Aug 22, 2023 | 01:11 PM
John CC's Avatar
John CC
Originally Posted by s8nw8n
air passes thru
Where is it getting air to pass through? Or is that a test you did? If the pump is drawing air in to pump then you don't have fuel at the pump inlet.
