Will pulling the main fuse isolate the battery?
I may put my Dyna in storage for a few months, and I was planning on disconnecting the neg terminal, since where it will be doesn’t have electric. But I was thinking it would be easier to pop off the breaker cover and pull the main fuse.
Nothing other then the tender tail is connected directly, so that should remove all parasitic draw, right?
Not sure on your bike, but my starter goes directly to the battery.
I think that's what Max is referring to when he says solenoid.
So anything else that required memory power will be off when you pull the fuse.
I have an oddball device, a 12v charger that works off a 12v battery. What I used to do when I was in NY and had a parking spot in a shared garage, was haul a 12v deep cycle battery to a bike stored too far from any outlets, and hook up this charger once a month to top off disconnected batteries.
Decided to put the Dyna in storage instead of trying to cram in into my new garage with a makeshift dolly. So I’ll do the same. Pull the fuse and bring the charger over every few weeks to keep it topped off.
Thanks gentlemen.
yep, starter always goes straight to batt. This answers my question.
Thanks gentlemen.
Thanks gentlemen.
