If you get the fuel pressure sorted out, and it still has the long crank problem, check into the crank position sensor, would be nice if you could find one to borrow just to eliminate it as a problem.
I did some exploratory surgery today and came to my conclusion on what the current problem is.
I removed the pump to check the oring for the fuel filter. That is where it looked like it was spraying out of. It was not and the oring was there. That got me looking at things around it. Lo and behold I found a gash in the fuel line from the pump.
I think the initial problem was the pump. Then when it was replaced the line gave up the ghost. I have a replacement on the way.
