New ignition switch on console!!!
Old Oct 28, 2007 | 07:37 PM
vivid06streetbob's Avatar
vivid06streetbob
Default New ignition switch on console!!!
i finally got my switch moved to the console
will try and get better pictures in the daylight
i used a factory 2003 and newer switch from harley, had to add about 12 inches to switch harness, hardest part is getting switch mounted to tank, made a plate out of aluminum 3/16 thick mounted it to sending unit bolts drilled and tapped it 8/32 for switch bolts, had to use plastic spacer in between switch and mounting plate, used 3/16 clear tubbing for edge of console, oh and used a 2" hole saw for the console, i know alot of us hate that damn switch on the frame neck i did, have about 6 hours in custom mok up time in the garage, but well worth it, tell me what everyone thinks
Bob out
[IMG]local://upfiles/28927/90A84E16772940CDB0CB4DF289DE691D.jpg[/IMG]
[IMG]local://upfiles/28927/AEBED379F7444DAC85A2BDA06545C9DF.jpg[/IMG]
[IMG]local://upfiles/28927/064C63503B5C47E8B6BC602EAB189279.jpg[/IMG]
[IMG]local://upfiles/28927/04C40A31378A49859FCB565BA8C2784C.jpg[/IMG]
[IMG]local://upfiles/28927/DEDB69E008DB41658D66B1491F1B3F06.jpg[/IMG]
Old Oct 28, 2007 | 07:47 PM
DougsDyna's Avatar
DougsDyna
Default RE: New ignition switch on console!!!
Nice job, and it looks factory.
Funny how they left just enough room for that switch to fit there.
DougJ
Old Oct 28, 2007 | 08:00 PM
1badtc88's Avatar
1badtc88
looks 110%, how hard or easy was it to do the wiring? what wires go where on the new switch??
Old Oct 28, 2007 | 08:06 PM
Muddyape's Avatar
Muddyape
Looks great....been thinking about this one awhile, another thing to do during the winter.
Old Oct 28, 2007 | 08:11 PM
vivid06streetbob
there are 3 wires on the stock switch a,b,c, just install same place, the connector is the same on both switches
there is a red wire, red/black and red with a grey stripe, i had to unplug stock plug and remove wires from plastic insulator so i could reroute wires back up and out on the left side, added about 12 inces of new wire soldered and shrink tubed all of
Old Oct 28, 2007 | 09:29 PM
AZ Rider's Avatar
AZ Rider
Nice job, Bob. Want to come to Arizona and do thatto mine? [sm=smokin.gif]
Old Oct 28, 2007 | 10:57 PM
vivid06streetbob
lets see can we say road trip!!
Old Oct 29, 2007 | 03:33 PM
vivid06streetbob
here is a clearer picture of the switch
[IMG]local://upfiles/28927/260C633B784A4052B0AC50C535BD5167.jpg[/IMG]
Old Oct 29, 2007 | 04:00 PM
mike1966's Avatar
mike1966
1.What did you do with old ignition switch?
2. How much did itcost you?
3. How long did it take?
Mike1966
Old Oct 29, 2007 | 07:41 PM
vivid06streetbob
left old switch in, it is just a fork lock now,
i bought the switch on ebay factory harley, i have about 100.00 and about 6 hours fab time
only bad thing now have two keys, will be checking into rekeying my ignition swtich to the same as the bike
not bad i guess, only need key to lock up bike now
soulpatch
May 27, 2019 01:14 AM
smat45
Apr 30, 2017 06:28 AM
just plain john
Nov 23, 2014 07:24 AM
ACE 1968
Electrical/Lighting/Alarm
Aug 14, 2014 11:21 AM
coondog888
Oct 31, 2011 09:44 AM
