Dumb Polyurethane Bushing question...
Old Jan 28, 2008 | 05:55 PM
JohnnyBoy's Avatar
JohnnyBoy
Default RE: Dumb Polyurethane Bushing question...
Don't know if this helps, but I had the stock MotoCo ones on for a week after I put on my 16" Apes. There was quite a bit of play in them (front/back) I'd say about 2 1/2 inchs in each direction. Put the Poly's in after a week and all the play was gone except for a hair. THe stock one's were black, the poly's were almost clear.
Old Jan 28, 2008 | 05:56 PM
HGM's Avatar
HGM
These are the same bushings I just put in mine. Bought them from the same guy.. BIG difference.. Not all Polly is clear, red, yellow, translucent, etc.... Push your thumbnail into the bushings. The new ones should have less give.. Put them in, for the money, you cant go wrong even if you dont like them.. I'm completely satisfied with mine and I've got 18" apes, no movement at all compared to the stock ones..
Old Jan 28, 2008 | 06:11 PM
rok312's Avatar
rok312
ORIGINAL: HGM
Thanks, HGM. That helps - I'll give 'em a try before jumping to any more conclusions.
Regardless, they were only 12 bucks after shipping, so its not like I'll have to dip into the kids college fund.
Old Jan 28, 2008 | 09:28 PM
HGM's Avatar
HGM
ORIGINAL: rok312
ORIGINAL: HGM
Yea, when I saw the dealer wanted $40 for theirs, it was an easy choice...Mine were in a Mid South shrink package marked Heavy Duty.. Like I said, best $12 I ever spent on the bike...
Old Jan 28, 2008 | 09:41 PM
BlueShift's Avatar
BlueShift
I just installed HD polys when I changed my bars totally different stock rubbers popped right out.
I had to tap the polys in with a mallet and block of wood. They are much stiffer.
Old Jan 28, 2008 | 10:18 PM
07bobber's Avatar
07bobber
polys will make a world of ddifference!!!!
Old Jan 29, 2008 | 04:34 PM
hk_shooter's Avatar
hk_shooter
Hey ShoreRider, you like them Arlen flush-mounts, are they worth it? Do they really clear up the under-side of the top tree?
TIA,
Old Jan 29, 2008 | 04:50 PM
Chipstah's Avatar
Chipstah
I got the GoodenTite poly bushings and yeah, much stiffer - you should really notice it. A bit more vibration but no slop, just don't over torque the riser bolts or you'll end up with virtually solid bushings and a lot of vibration (comparatively speaking).
Old Jan 29, 2008 | 06:20 PM
ShoreRider's Avatar
ShoreRider
ORIGINAL: hk_shooter
TIA,
Hk...totally into them. So much better than looking at the stock MoCo hex bolts. I've attahced 2 photos for you to see what they look like.
[IMG]local://upfiles/45553/FC27791F8A8B4A54BA0AB5F6C67BBABF.jpg[/IMG]
[IMG]local://upfiles/45553/62F9F74D88904D32A04D5EF920855B10.jpg[/IMG]
Old Jan 29, 2008 | 07:23 PM
Airborne350G's Avatar
Airborne350G
Those look a hell of a lot better then stock....
