Suggestions
Old 02-05-2008, 10:34 PM
DerbyBob32's Avatar
DerbyBob32
DerbyBob32 is offline
Stage III
Default Suggestions
I have an 06 superglide custom. I would like to change the wheels to 17" front and rear with black rims and hubs. My bike came with alloy wheels. Would the easiest way to do this be to find some stock spoke wheels and have some rims and the hubs powdercoated? Would i have so much $ wrapped up in doing this that i should just buy new wheels? I noticed that there arent many choices for the 1" axle. Thanks
Old 02-05-2008, 11:05 PM
KooeL49's Avatar
KooeL49
KooeL49 is offline
Default RE: Suggestions
Yes powder coating and lacing a new rim on your hub is the easyest/best way. I am in the process of the same thing. Find some rims (JPCycles is a good start), find the spokes you want, strip your current wheels, take the hubs and new rims in to a local powdercoater at the same time and try to get a bulk deal. Then learn to lace them, do it your self, then take them in to get tuned. My figure is under 500 this way for both rims. Good luck.
Old 02-05-2008, 11:27 PM
DerbyBob32's Avatar
DerbyBob32
Stage III
Dont currently have spoke wheels, that ismy main problem. I dont know enough about the different hub sizes and whatnot to find the right ones for my bike. In theory if i can find some stock spoke typehubs for an 06 it may not be too bad of a swap.
Old 02-06-2008, 12:08 AM
fiend138's Avatar
fiend138
fiend138 is offline
I am not for sure but do they make a 17" front, are you going to have to go to a 16? If I had the chioce time and $, i would go 16 then you can buy white walls all day long.
Scarz
12-31-2010 02:35 PM
ADCD875
10-16-2010 01:01 PM
sgtrod91
05-20-2008 09:17 AM
mcurry5
05-16-2006 01:52 PM
Beefcake
Product Reviews
06-04-2005 12:36 AM
Quick Reply: Suggestions
