Ing coil
I just bought a 03 wideglide. A screaming eagle kit was put in. It is now a 1550cc. I think the coil is stock. Should I put a high performance coil in and what brand? It has a carb. Thanks Alan
What kind of ignition module do you have? Some of the Screamin Eagle ignition kitscame with an "exclusive"coil. This SE coil is, or at least was, available separately as part # 31704-99 for a Dyna. If you have an SE 31713-01, 31775-01or 31710-01 ignition, you probably already have this coil.
Daytona Twin Tec also has a high output coil as part #2008.
I doubt you will tell any difference from changing the coil unless the stock one has a problem.
KingPinVinny
May 4, 2010 02:36 PM
