Anyone know a trick on how?
Does anybody know of a trick to get the main wiring back into the backbone of the bike? I have tried and tried and tried and cannot for the life of me get all that to fit back into the bike. Would appreciate it anyone could help me out on this. Thanks in advance
RE: Anyone know a trick on how?
Pull your rear wheel off. There is a rubber flap on the underside of the fender towards the frame, pull it off. It will give you access to the wiring loop. Figure out which bundle of wires you pulled out from the backbone & try "looping" a hanger or twine or something around it, or if you can, grab it with your hand & pull it back thru towards the back end. When you get the extra wiring pulled back thru, curl it up & tuck it into the area between the frame & rear fender & put the rubber flap back on.
It's easier to do with 2 people because sometimes you need some back & forth action to get the wire pulled back thru the frame, but you can manage it alone with some patience. I've done it a couple times by myself.
ORIGINAL: Brian8
Yeah I have the rubber flap off but the back tire is still on.. I pulled everything through and now its all hanging out the back end. I tried stuffing it from the back end up but can't fit it all back in.
It is ALOT easier to do if you have the rear wheel off. I changed out my handlebars & did the whole thing without a jack or removing the rear tire. Changed out the front end & put on apes & used a jack & took the tire off. I couldn't believe I'd done it the 1st time the way did.
You can fit your wiring in there, it was all stuffed in there before. You have to force it in there.
