Wiring multiple amps
Old Nov 10, 2017 | 07:16 PM
D_Cantelow's Avatar
D_Cantelow
Default Wiring multiple amps
Looking for directions on how to wire two amps into a set up. 2012 SG with pioneer HU. I will be adding a small amp to run my horns. What additional parts are required? Looking to fit both inside the fairing.
Old Nov 10, 2017 | 09:52 PM
sponger's Avatar
sponger
Ok so, u run the 2nd amp EXACTLY how u ran the 1st amp. Except u can run a remote turn on from one amp to the next. Done. Not that hard.
Old Nov 11, 2017 | 06:29 PM
SOFTPETER's Avatar
SOFTPETER
A bunch of different ways to wire.
Whats the model numbers of the amplifiers?
Old Nov 11, 2017 | 06:49 PM
D_Cantelow's Avatar
D_Cantelow
Currently using the DD D4.90. Haven't picked the second amp. Thinking maybe the D4.60, soundigital 250.2, or the AD 400.4. Just looking to get a grasp on the plan before I start.
Old Nov 11, 2017 | 10:01 PM
SOFTPETER's Avatar
SOFTPETER
No outputs on that amp so you will have to use some Y adapters for the signal, unless you use an outboard crossover.
The other thing you could do is to find an amp with outputs for your "A" amp, then use that one for your "B" amp.
wiguy
Audio Systems
Mar 15, 2016 09:39 AM
bettingpython
Audio Systems
Jul 14, 2015 06:15 AM
Chad c
Stock Harley Take Offs
Apr 19, 2015 11:39 AM
SALBEEZY
Audio Systems
Jul 8, 2014 11:54 PM
jcrawford14
Audio Systems
May 14, 2014 09:32 PM
