New speedo/ Tach for Street bob
RE: New speedo/ Tach for Street bob
According to the instruction sheet the procedure is as follows:
For All Models: Back Lighting Adjustment
To adjust the color of the back lighting:
1. Turn the Ignition/Light Key Switch to ACCESSORY.
2. Press and hold the "Trip" reset switch until the odometer reads "COLOR".
3. Release the reset switch.
4. Click the trip reset switch to scroll through the available colors using the coarse adjustment in +20 increments.
5. Press and hold to fine tune the color adjustment.
6. When the desired color is reached, the gauge must remain powered, and the button released for 5 seconds.
7. When the color is set to the word "COLOR" will no longer be displayed in the LCD. The gauge automatically reverts back to display the mileage. Power can then be turned off.
8. If the color is not set in the first attempt, repeat Steps 1 through 7.
Location: Back in the Good Ole USA. South Carolina to be exact.
Sickpainter
Dyna Parts
04-24-2013 11:28 AM
2006, 2008, adjustment, bob, color, fat, ignition, key, replace, speedo, speedometer, speedotach, street, switch, tach
