Slip on pipes
Old Jun 2, 2008 | 08:26 AM
BigDaddyMongo's Avatar
BigDaddyMongo
Default Slip on pipes
If i put on Python 3 slip on pipes do I need to buy a power commander or new air intake? Or is it just removing the factory pipes and installing the slip on pipes? Or does anybody know a good loud sounding slip on pipe I can use. I have a 2008 FXDC EFI
Old Jun 2, 2008 | 10:40 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: Slip on pipes
Most likely not if you just put on slip onpipes you will run a little bit leaner but not too much. If you change the air cleaner to a high flow you will definitely need a fuel management device.
Old Jun 2, 2008 | 11:04 AM
2007fxdc's Avatar
2007fxdc
ORIGINAL: KBFXDLI
+1, the conventional wisdom around here is that you don't need to do anything if you only change the slipon mufflers to most of the popular models. Consider a high flow a/c and an ECM air/fuel adjustment of some sort dependent on each other. Best suggestion is to install the mufflers and then check your plugs to make sure they aren't real white indicating an overlean condition. If you see that at any time, you should consider adjusting the air/fuel mix and that's also a good time to add a high flow air cleaner.
Overlappinglittlepig
Jun 14, 2021 10:52 AM
Tonus
Exhaust System Topics
Dec 10, 2010 07:58 PM
Roger Williams
Mar 17, 2010 01:07 AM
jerrjazz
Nov 15, 2008 09:23 PM
JCB
Jun 28, 2007 12:59 PM
