Rear Wheel Off Center
Something I learned
My bike was in an accident a couple of years ago and I noticed to bikes rear tire was off center to the left by a good bit (1/2 inch or more) \\; I researched and found that this is really not uncommon. \\; I remembered the bike being off some before the accident so I didn't worry about it. \\;
I did allign the bike as best I could by following the directions in the service manual. \\; Loosening the mounts in 3 locations turning over the engine and most of the things stated in the process.
one of the things it said was something like if you have to turn the top mount more than 5 turns go see the dealer and yoou should adjust it so the bolt drops strait in.
I noticed the engine has the swing arm connected to it and the rear mouont of course connects the engine to the frame. \\; After this realization I figured adjusting the top brace would move the rear wheel as I needed it. \\; It worked. \\; I loosened all the mounts and tightened the top mount and then pryed the engine over to meet the new location. \\; Now the rear wheel is centered in the fender as it should be.
notes
the bike roled strait before and after this adjustment.
the rear tire developed a shoulder after 1-2 thousand miles. (adjustment should fix this)
sometimes you have to use your head and ignore the service manual.
Hope this helps someone......
notes
dchoran
07-25-2008 03:05 PM
