I need Air Shock Help?
Old 07-02-2008, 10:50 PM
schmittles's Avatar
schmittles
schmittles is offline
Default I need Air Shock Help?
I installed a pair of the low profile(12in) touring air shocks on my bob.&nbsp\\; They the chrome aftermarket ones that midwest motorcycle supply makes.&nbsp\\; I purchased them from Easternperformance.&nbsp\\; Well anyways, I did not recieve any instructions on what the recommended air pressure requirements are.&nbsp\\; I have head Joe say you put be between 5 &amp\\; 10 psi and then I have heard you put the smae amount of air as the harley ones between 19 &amp\\; 25 psi.&nbsp\\; I called Eperformance and their tech is gone for the next week.&nbsp\\; I called midwest and they refused let me ask the them my question.&nbsp\\; So any of you dyna riders out that have put on the touring shocks, did you get type of air pressure requirement info and if so, what are the specs?
&nbsp\\;
&nbsp\\;
Old 07-03-2008, 08:46 AM
ny06fxdb's Avatar
ny06fxdb
ny06fxdb is offline
Default RE: I need Air Shock Help?
I just installed the HD air shocks on my Bob.The HD instructions say 0 to 5 psi up to 200 lbs, 5 to 10 psi for&nbsp\\; 200 to 250 lbs. 10 psi and up for over 250.&nbsp\\;
Old 07-03-2008, 11:38 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
same! how do you like the ride?
Old 07-03-2008, 01:32 PM
Two Feathers's Avatar
Two Feathers
Two Feathers is offline
&nbsp\\; I want them on my lowrider so bad, but can't find out what size I need.
I have looked and looked, can't find it.&nbsp\\;&nbsp\\;&nbsp\\; Help??
Old 07-03-2008, 05:14 PM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
Recommended air pressures
[/align]0-10 lbs for a 150-lb to 200-lb rider.
[/align]5-15 lbs for a 200-lb to 250-lb rider.
[/align]20-25 lbs for a rider with passenger.
[/align]FL air preload rear suspension range is 0-35 lbs of pressure.
[/align]FLHRS and FLXH low-profile shocks are 0-50 lbs max.
Old 07-03-2008, 05:35 PM
schmittles's Avatar
schmittles
Thanks guys for the info.&nbsp\\; This helps a bunch.&nbsp\\; The ride is grrrrreat.&nbsp\\; I just installed jackyl's 2in tank lift.&nbsp\\; I will post pics soon.&nbsp\\; Happy Fourth of July everyone.&nbsp\\; Ride Hard and Ride Safe.
Old 07-31-2008, 11:11 AM
Thewaxmania's Avatar
Thewaxmania
Thewaxmania is offline
This may have already been discussed on this forum, but which HD part numbers work for the lowering air shocks.&nbsp\\; I've got a Dyna that I want to replace the low rider shocks on and put the 12" air shocks.&nbsp\\; I know part number 54631-98 will work, I'm wondering if 54662-02A will work.&nbsp\\; The bike is a 92 FXDC but I want to lower it just a bit since I'm not that tall and the bike is spindly to begin with.
Old 07-31-2008, 03:44 PM
PKellyMc's Avatar
PKellyMc
PKellyMc is offline
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Love your Green Machine, WS6.&nbsp\\;I think it's begging for the chrome lower belt guard, though. Just my opinion, but I am recognized as the world's leading authority in my opinion.
Old 03-16-2012, 07:19 PM
dtone72rss's Avatar
dtone72rss
dtone72rss is offline
I have a pair of 06 flhx shocks on my 07 SB. i weigh 245 with gear. i filled them with 11oz of 7 wt.
Is my fluid level right, and what air pressure should i run solo or two up.
thanks
Old 03-17-2012, 10:06 AM
1HD1C's Avatar
1HD1C
1HD1C is offline
oil weight not being discussed here and thats very important
the touring shocks come with 5wt which will be way to squishy
for the ride angle on the dynas.
when i put a set on my wide glide last year i took them off the same
day to replace the oil i went with a 10wt synthetic and only needed 10lb
with me at 160 and 15-18 with my wife on the back at 130 the ride
was perfect.
so if you can find out what weight came in the new shocks it will go
a long way in determining what air pressure you need to run in them.
dtone
with 7wt i would start at 10lbs and go up 2lbs at a time from there.
mayhemmaster
07-04-2014 05:33 AM
harleyflo
02-27-2011 08:18 PM
hyperfocal
01-03-2009 10:34 PM
MR. SCOOTINN
04-30-2008 04:10 PM
retimms
06-17-2006 01:05 AM
Quick Reply: I need Air Shock Help?
