Hot day air has built to 8o psi and i go to let air out...never done this before.. push steem in and nothing..get a a]steem remover and unscrew it ..nothing I have read u need a pump HD to add air
Am i to assume i need this pump tp let air out ??
thats what i need..still not sure why air wont bleed off with pressing steem in unless its empty ,,
I think you might have a winning answer here. If you don't have a pump, thus never have put air in them, then they are probably empty or damned near it. They will lose air pressure over time.
You will be amazed at how much better the ride is with proper air pressure in the shocks.
yes first season with this bike.. first touring as well
found it weird to bottom out with wife on back so i tried reading as much as possible will have to get pump to c pressure
yes i am...dam i feel like a idiot so only a pump/gauge can read pressure?
I know it's not right to laugh at others but I'm sorry....that was funny as hell. Get you a pump and all will be good. Pump it up to about 15-20 psi riding solo.
I am around 230 lbs. and the manual says the shocks should have about 25 or so in them for that weight solo, and about 40 2 up. I put mine at 40 and left them there for solo to make it easier. I personally like the ride better at 40 solo too.
