turn signals
Old Mar 29, 2006 | 03:18 AM
clayman's Avatar
clayman
Default RE: turn signals
i used them with the stock signals, the only thing you have to do is replace the bolt that comes with the clamp its a course thread and you need a fine thread with the stock signals.
Old Mar 29, 2006 | 03:57 PM
capefearband's Avatar
capefearband
6th Gear
I think the Kuryakyn silver bullets look much better than stock anyway....
and the price is OK
Old Mar 29, 2006 | 11:03 PM
billybobber's Avatar
billybobber
ORIGINAL: clayman
Clay, which signal brackets do you have? the ones out of the drag specialties catalog or the kuriaken ones in the picture? I would like to know too if the kuri units will work with stock turn signals....
Old Mar 29, 2006 | 11:11 PM
LOWTOW's Avatar
LOWTOW
I'm using the same type that BlackOak has. Very clean and much less clutter around the bars.
ORIGINAL: BlackOak
Get some Turn Signal Mirrors.....really cleans up the front end. I got these off ebay for a 100 bucks
Old Mar 30, 2006 | 01:10 AM
clayman's Avatar
clayman
i got them out of a drag specialties cataloge but the part is made by kuryakn. It is the only 49mm fork braket available to my knowledge. They work great easy to put on, but i personally dont like the look, i think it takes away from the clean looking fork, and i love the way those new 49mm tubes look. I am going to go with the mirrors with signals in them, they look the best in my opinon, and by the time you buy the braket and the new signals you could have bought the mirrors.
Old Mar 30, 2006 | 01:27 AM
BlackOak's Avatar
BlackOak
Suggestion........the wiring in the Turn Signal Mirrors is very small. Take a Cat 5 cable ( computer network cable) peel it open and take out 4 strands of the cabling. Its a perfect match for the the mirror wiring.
Old Mar 30, 2006 | 09:50 AM
LOWTOW's Avatar
LOWTOW
Good tip BlackOak. I have plenty of CAT 5 lying around here. The thicker wire was a PITA to feed into the bars especially with the soldered splices.
Old Mar 30, 2006 | 10:41 PM
billybobber
ORIGINAL: clayman
gotcha....
thanks
08streetbobbin
Mar 21, 2014 04:48 PM
Kergee6996
Jan 29, 2013 01:05 AM
CKS
Mar 15, 2011 09:15 AM
dpriest
Dec 21, 2008 08:53 PM
larazauk
Feb 22, 2008 12:12 PM
