"Foggy" Headlight
Funny that you ask.
I noticed the same thing on my 06 Dyna Custom and did some cleaning last night.
I removed the light and sprayed some water in the lens and drained. I then sprayed some s100 cleaner and let it sit for a few minutes and rinsed. It was a lot better but still had a film. I then used some glass cleaner a managed to get a finger in there with a rag and wiped it down (the chrome part that is, the glass lens was clean). I then rinsed again, and used some compressed air to get all the moisture out. Reassemble, tested and the lens looks crystal clear.
It seems like a lot of work but it only took about twenty minutes from start to finish.
I hope this helps.
I hope this helps.
