Cleaning Haze from Headlight Reflector?
Old Mar 9, 2009 | 02:38 PM
SFTL 1's Avatar
SFTL 1
Default Cleaning Haze from Headlight Reflector?
I'm using the current 05' & later headlamp with the clear lens. The lens reflector optics seems to have a slight haze or fog on it. I recall someone saying that it's caused by the residue of a protective film on a new bulb that gets burnt off. Not sure if that's the cause or not, but either way, what is the best way to clean the inside of this headlamp? I also recall someone saying to use denatured alcohol and swish it around inside the lens (with bulb removed obviously), drain and then let dry and had good results?
PhilG57
General Topics/Tech Tips
Jun 2, 2014 07:49 PM
wintersucks
Mar 17, 2013 11:42 AM
discodave
May 5, 2012 09:09 AM
Tampa Fatboy
Apr 11, 2012 06:30 AM
Steele
Dec 18, 2010 12:01 PM
