Can this be done?
Old Dec 23, 2008 | 04:22 PM
armybrat02's Avatar
armybrat02
Default Can this be done?
Is it possible to use the stock laced wheel hub to a wielder hoop? I am considering trading for some laced wheels but want to know if I can re-lace them to a new hoop to mount a 200 on my bike.
Old Dec 23, 2008 | 04:24 PM
wkdavistx's Avatar
wkdavistx
If they have the same number of holes, and the holes are the same size (i.e. NOT fat daddy wheels) then you should be OK.
Old Dec 23, 2008 | 04:38 PM
JRK5892's Avatar
JRK5892
and the spoke pattern LINES UP!!! that is a huge one!
Old Dec 23, 2008 | 09:28 PM
nkauf21's Avatar
nkauf21
Yes you can. My stock rear hub is laced to an 18x5.5. I'm running a 180 but a 200 can mount on the 18x5.5 also.
Old Dec 23, 2008 | 09:35 PM
trainhopper's Avatar
trainhopper
6th Gear
sdfasdfasd
Old Dec 24, 2008 | 01:24 AM
benwiggin2's Avatar
benwiggin2
Originally Posted by trainhopper
sdfasdfasd
Exactly!
Old Dec 24, 2008 | 08:53 AM
armybrat02's Avatar
armybrat02
thanks for the quick responses. If I were to do it what would be the best place to go and hoop to go with?
Old Dec 24, 2008 | 09:11 AM
Stanger's Avatar
Stanger
It should work fine. I re-laced mine to a small in width and Dia. rim. Just make sure that you are getting a 40 spoke rim.
Just find a rim, you could lace them up. I have done about 6 set now and honestly they are not bad. The front is the worse of the two, still my first time I did it on a Sat. afternoon.
As far as where to get a rim or .....
Try here: http://www.hdwheels.com/
Good luck!
ryan9977
Sep 11, 2015 06:11 PM
jpooch00
Apr 28, 2015 07:07 PM
p51bombay
Jun 7, 2013 01:58 AM
Sgt Sportster
Wheels/Tires
Jun 25, 2011 12:23 AM
voigtster
Dec 6, 2008 08:06 AM
