Fat Bob + Windshield = question
Old Dec 26, 2008 | 08:31 AM
Centerline's Avatar
Centerline
For sure it is a little, somewhat, or a LOT goofy mounted low. Not much of a fashion statement mounted higher either for that matter
Thanks for the heads-up about the rubber grommets Bill- XFDF. Do you know if they are sold separately?
Old Dec 26, 2008 | 08:43 AM
TowJam's Avatar
TowJam
Originally Posted by SC-Longhair
I don't think there is a windshield out there that you won't exp. some sort of buffetting.
I'm spoiled - I've owned several sport tourers with adjustable screens that had absolutely zero buffeting. Harleys? Eh, no so much.
Old Dec 26, 2008 | 08:52 AM
Gamma742's Avatar
Gamma742
The only way to get rid of the Buffeting is get lowers. I know, I know.. They look worst than dropping the shield below the triple trees (been there done that). Huge difference with the lowers from Memphis Lowers, moving the shield down lead me to the lowers.
Old Dec 26, 2008 | 10:06 AM
Stinger's Avatar
Stinger
Hmmm.... I'm 5'10" and have the windshield set in the "normal" position and dont think the buffeting is that bad. A little bit but not enough to make me want to move the shield.
The shield could look good as positioned in Centerline's pics if the cutout were modified to clear the headlights. Not sure how many people want to hack their shield like that though.
I'll take a little buffeting over the blast of cold air this time of year! (riding in Maryland)
Old Dec 26, 2008 | 12:42 PM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
I had a touring (I think) windshield with my 94 Low Rider. Pear shaped and sort of wrapped around at the bottom. Great, almost no buffeting. Can't get em anymore.
Old Dec 26, 2008 | 01:21 PM
luckyB's Avatar
luckyB
Originally Posted by Centerline
Harley low profile windshield mounted very low on FXDF Fat Bob. No more obnoxious buffeting at highway speeds.
Do you get much protection with the windshield mounted that low? Great idea though.
Old Dec 26, 2008 | 02:41 PM
catalac's Avatar
catalac
From researching this same subject a few months ago I found the guys with a Windvest screen talked pretty positive.
I have not bought one yet but plan to this spring.
Old Dec 26, 2008 | 09:09 PM
HD Jake's Avatar
HD Jake
I have the standard quick detach windshield on my Bob and at 80 mph have very little buffer... I wear a 1/2 helmet so I cant speak to the full face helemt, I have a extra windshield that I got off ebay for cheap and cut it down with a jigsaw for summer when I go on longer trips
Old Dec 26, 2008 | 09:31 PM
Bumbobee's Avatar
Bumbobee
Sorry Im a total noob, what is buffeting and how would having a standard size harley windshield on a Fat Bob make "buffeting"?
Old Dec 27, 2008 | 07:55 AM
Tnbrit's Avatar
Tnbrit
Default Touring Shield
I had the Full Size Touring Detachable on my FXD,couldn't stop the Buffeting,the best position was it's lowest,the wind comes up from underneath,lowers sound like the best cure,I got fed up with it so I bought a full face.Solved the problem with buffeting but a lot of body pressure above 70mph,so I changed out the standard FXD bars for lowrider bars,much reduced pressure i'm now about to fit Drags,so I lean more into the wind,& not upright like a sail,hope that works!.Harley IMHO need a proper aerodynamic shield solution.
Brit.
