carb tuning
Old Jan 4, 2009 | 11:27 AM
jfm5's Avatar
jfm5
Smile carb tuning
how easy is it to tune the carb yourself air/fuel screw adjustment do you need any special tools or if you tune your own could you give us any tips thanks
Old Jan 4, 2009 | 11:36 AM
sportncruise's Avatar
sportncruise
When you say "tune" what are you actually trying to do?
Change jets, shim needle, adjust air/fuel screw, adjust float.
Or are you trying to synch 2 or more together?
In the case of the synch a carb tool is necessary and there are lots of options for this from cheap mercury to expensive.
For doing jets if you know what jets you want/need based on what someone told you buying jets are cheap. A kit is more expensive.
Pulling them out and replacing is simple and no special tools.
On the carbs I have done the air/fuel screw is usually blocked and I had to take a drill bit and remove some metal to get to the screw.
http://www.carbtune.com/ This is what I have and in no way associated. I tried mercury but after it spilled I got rid of it and bought this one.
Old Jan 4, 2009 | 11:54 AM
jfm5's Avatar
jfm5
it was just the air/fuel screw adjustment
Old Jan 4, 2009 | 02:02 PM
sportncruise
No special tools just a screw driver.
This website explains air/fuel screws in relation to the idle jet.
http://atv.off-road.com/atv/article/....jsp?id=190926
http://www.exriders.com/archive/topic/229923-1.html
Another one that explains the difference between air screw and fuel screw in relation to 2 stroke or 4 stroke.
Might try looking at a kits website to see what they recommend for your model but it isn't hard at all.
Old Jan 4, 2009 | 03:27 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
JFM, to remove the plug covering the the air mix screw take small drill and carefully just puncture the plug, take a small screw, screw into that hole and pull out the plug. If you have an open intake (SE intake) raise the needle with two .040 brass washers (don't know how that would work out in metrics) or install an old sporster needle p/n 27094-88, your dealer should have one or able to get one. The adjustments on the screw are from lightly seated (screwed in) to 2.5 turns out, that should put you in the ball park.
Old Jan 4, 2009 | 07:30 PM
BigLowRider's Avatar
BigLowRider
Good info here ...
http://www.harley-performance.com/ha...arburetor.html
BigLow
Old Jan 5, 2009 | 01:21 AM
rounder's Avatar
rounder
do this! http://www.ridermagazine.com/output.cfm?id=217441
also note that at sea level a #46 /190 jet combo may work better than the #45/ 190 stock combo.
Old Jan 5, 2009 | 06:31 AM
jfm5's Avatar
jfm5
Default thanks
some good useful information there thanks all of you
Old Jan 5, 2009 | 11:23 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
NightRider has some good info.
Old Jan 5, 2009 | 03:06 PM
cornishman's Avatar
cornishman
One small tip, make sure you have a clean air filter and all other adjustments like plugs are correct, your motor is at full working temperature and then set your carb.
