Inner Primary Cover
Old Feb 24, 2009 | 12:09 PM
reded's Avatar
reded
Many thanks for the drawings. Shouldn't be a problem carving one of those out.
Old Feb 24, 2009 | 12:27 PM
07bobber's Avatar
07bobber
Mud do you happen to have any pics of the ipb location and a write up on it and maybe a how to for a clutch replacement.
Old Feb 24, 2009 | 01:11 PM
mud's Avatar
mud
bobber, clutch replacement??
no write up of mine. I'll be getting in there soon. Try to do it then.
Follow the manual, it's not a big deal.
Pay attention to the order that the discs and plates come out.
Soak discs if installing new ones.
Screaming Eagle spring is a good upgrade (if needed).
On the hiPower builds also add the VPC.
ipb location??
behind the seal in the first picture
(this is the back side of the inner primary case)
Might as well show my race puller
the inner bearing rides on this race.
It is a real MortarForker getting this race off.
It can also be cut off,
that's a touchy operation
psycho posted this picture of his bearing a couple years back
Old Feb 24, 2009 | 01:26 PM
07bobber's Avatar
07bobber
Thanx mud i apreciate it...i have a very and i mean very slow leak i think coming from that seal on the ipb. It only leaks after a 200-300 mile ride maybe 3 or 4 drops under the primary after sitting overnight. But the back of the primary is definatly wet....
Old Feb 24, 2009 | 01:28 PM
07bobber's Avatar
07bobber
Also what is the vpc you mentioned?
Old Feb 24, 2009 | 01:42 PM
04fxdwgi's Avatar
04fxdwgi
Red face
ipb location??
OHHHHH to have a tig welder handy again....
That bearing is hurting..... Almost looks like an etched roller and looks to be the only one HMMMMMM
Old Feb 24, 2009 | 01:46 PM
Black Bart's Avatar
Black Bart
Default Ha! Ha! Ha!
Originally Posted by reded
OOH LA LA, wherever did you come up with that fine piece of toolery? Looks like it would do the trick much better than trying to stuff my big mitts around the oil laden tensioner assembly and try to get it wedged into place without having it unload itself.
With the proper dimensions I could set out making one, that is, unless I would be money and time ahead just buying it.
Ever think about using a tie wrap on it and then after it's in place cutting the tie wrap?
Bart
Old Feb 24, 2009 | 01:50 PM
Black Bart's Avatar
Black Bart
Smile Excellent photography
ipb location??
Thanks for these beautiful pics Mud!!!
Bart
Old Feb 24, 2009 | 06:36 PM
1skrewsloose's Avatar
1skrewsloose
I want to thank all who replied to this thread, my shifter arm has been loose for awhile, needs to be replaced. Was caught between dealer and garage. New here and always amazed at the amount of knowledge at this site. Thanks again.
Old Feb 24, 2009 | 08:25 PM
mud's Avatar
mud
That leak could also be coming from the transmission seal.
yeah 04 I wish I had heliArc handy again as well.
The puller is fused with my little wire feed machine
Don't remember if Psycho said some of the other rollers were damaged, or not.
Bart
Bart, that's exactly how it's done if you don't have the tool.
Glad you like the pix.
bobber, I should have typed that out. . VPC . Variable Pressure Clutch...
http://www.aim-tamachi.com/home.php?cat=3
The harder the motor hits,
the tighter the clutch discs and plates are clamped together.
Don't need it unless you gotta lotta motor.
VPC device is the green arrow below.
Red arrow is the Screaming Eagle Spring..........
