Inner Primary Cover
Old Jan 7, 2009 | 09:08 AM
Shrug's Avatar
Shrug
I cheated and bought the Kury chrome cover.
Old Jan 7, 2009 | 01:17 PM
GREENOHAWK69's Avatar
GREENOHAWK69
+2...and easy as pie to install.
Old Feb 23, 2009 | 07:53 PM
SURFOR Chop's Avatar
SURFOR Chop
Mud -
How much stress is put on the 7" bar stock? I have 1/8 piece, but not 1/4 ... think that'd work?
R/
Priest
Old Feb 23, 2009 | 08:08 PM
WGJ's Avatar
WGJ
Get the 1/4" bar. The 1/8" will not hold up when breaking the loctite.
Old Feb 23, 2009 | 08:10 PM
reded's Avatar
reded
1/8 inch would more than likely work. Its not a hard job at all just a little time consuming. Installed a set of forwards on a buddy's bike this weekend in right at two hours with a massive hangover from Friday night. The worst part is getting the auto tensioner put back together and installed without it springing back apart and pissing a person off.
I take that back, THE WORST PART is that H-D attempts to use every different type of fastener style known to man. May as well dump the entire toolbox on the floor and go to work, cause thats what it'll look like when you're done.
Old Feb 23, 2009 | 09:07 PM
Wireguided's Avatar
Wireguided
No kiddin on the tool box on the floor............
Old Feb 23, 2009 | 09:08 PM
mud's Avatar
mud
Originally Posted by Priest
Mud -
R/
Priest
Should be fine Priest.
Guinea Pig it and let us know
or, double up on the 1/8" stock
red
Here's a picture of the tensioner reassembly holding tool..........
Old Feb 23, 2009 | 09:39 PM
reded's Avatar
reded
OOH LA LA, wherever did you come up with that fine piece of toolery? Looks like it would do the trick much better than trying to stuff my big mitts around the oil laden tensioner assembly and try to get it wedged into place without having it unload itself.
With the proper dimensions I could set out making one, that is, unless I would be money and time ahead just buying it.
Old Feb 24, 2009 | 05:38 AM
sniper77's Avatar
sniper77
I've heard a zip tie around the tensioner before disassembly is a real effort saver....
Old Feb 24, 2009 | 10:43 AM
mud's Avatar
mud
here you go red.
tie wrap also works. this is faster.
make one, or just ask your favorite HD Tech to give you one.
that's where mine came from.
I believe these come along with purchase of new tensioner.
clips onto nubs pointed out in the second picture...........
