Winter tear down
Old Feb 11, 2009 | 09:47 PM
redrubicon2004's Avatar
redrubicon2004
Old Feb 12, 2009 | 04:24 PM
jhall201's Avatar
jhall201
Originally Posted by 07bobber
Great pics i wanna do some work to my bike but im not touching it until i know which cams bb kit and head work i want for sure i want to do it all at once too.....
I have a 2007 SB and I used SC204 cams, big breather, Vance & Hines Big Radius 2-2, and ported and polished the heads. 95 HP, 105 Torque.
Old Mar 7, 2009 | 03:54 PM
redrubicon2004
Well, I got most all my parts. (didnt get pics of all of them) And its time to start some assembly. I am still waiting on the engine. The machine shop still has everything.
Break down of new parts (I have alot of work to do!)
SE pistons
SE cam plate
SE high volume oil pump
SE tapered push rods
SE clutch plates
SE clutch spring
HD "B" lifters
Andrews 37G cams
Andrews gear set
S&S cam install kit
Mikuni 42mm carb
Jerzee customs oil pressure gauge
raptor shift light
Hayden auto primary chain tensioner
progressive 412 12" shocks
progressive drop in lowering kit for front
Metzeler ME880's comming soon
Heads are getting ported, CC'd (Going for 9.8:1) 1.90 intake and 1.625 exhaust valves, Springs, guides, and compression releases.
Jugs bored to 95"
Crank trued and welded along with Timken bearing upgrade
Since I still dont have the engine back, but cant wait. I got the cams and cam plate ready for install.
Small mistake. I put the outer gear on without first realizing that it is now in the way of one of the cam plate mounting bolts
Thats it for now. I will be getting the cases, crank, jugs and heads back on Mon or Tues. More pics to come later next week!
Old Mar 19, 2009 | 05:00 PM
redrubicon2004
I got the heads back today! Hopefully I will get most of the engine back together this weekend.
Ported, 1.90 Intake, 1.625 Exhaust, Bronze guides, New springs, compression releases, CC'd and milled.
Here are some pics of the heads.
Old Jan 24, 2011 | 02:56 PM
gdt3's Avatar
gdt3
Hey redrubicon2004, is there any specific reason you went with the Hayden Primary Chain Tensioner instead of the Southern Oregon Hot Bikes hydraulic one? I'm trying to make that decision.
Cheers,
Don
Old Jan 24, 2011 | 08:47 PM
redrubicon2004
Cheers,
Don
I actually swapped that one out for a 06-up style one. Works much better.
Old Jan 25, 2011 | 02:05 PM
gdt3's Avatar
gdt3
Hi Chad. Thanks for the reply. Can I clarify which one you swapped out, the Hayden or the SOHO one. The 06-up style one that you switched to, is that the Hayden or the HD factory one? I would just like to be sure and not make assumptions.
Many thanks,
Don
Old Jan 25, 2011 | 07:13 PM
redrubicon2004
Many thanks,
Don
I used the factory one most recently. I like it better.
MileHighDyna
Sep 2, 2019 07:16 PM
Sauraus
Engine Mechanical Topics
18
Jun 26, 2018 06:18 AM
Doshounds
Touring Parts
Jul 13, 2015 07:45 AM
dfowler1
Touring Parts
Jun 1, 2015 08:32 PM
