shock install
Old Mar 3, 2009 | 06:40 PM
mud's Avatar
mud
Arrow shock install
Installing shocks.
Simple operation.
30 minutes to an hour, taking your time.
Ohlins HD2191. 36PRLCB
thanks Howard.. appreciate it...........
Lift the machine. Support wheel.
Cover anything that may be damaged if you drop something.
Remove the shocks.
Use tap to clean the old Threadlocker out then spray with BrakeKleen.....
Hardware below.
New bolts if needed.
On my 006 FXD, these are 1/2 inch..13...3 1/2 inch upper..2 1/4 inch lower.
standoffs, sleeves, washers.
Threadlocker, 243. One good drop, as shown, don't overdo it.
Torque Values for my 006 FXD.......
upper.....75-85 ft lbs
lower.....30-40 ft lbs
installed..
I was afraid the Crime Scene Tape yellow was gonna stick out like a Sore Thumb.
But, it compliments the Arrest Me black tins nicely.
the Stay Back 50 Feet yellow just says fine functional equipment to me...........
installed detail
initial spring preload is set at 6mm in...........
Done.
Now to put on a tShirt and ride up to the cafe for enchiladas and maybe a cold drink or two.
Gotta love the South Texas winter.
big-e976
In Memory Of...
Sep 27, 2014 09:40 AM
