Neutral?
Old May 3, 2006 | 11:49 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: Neutral?
get it checked for the recall and then put 75w90 gear lube in the trans.
Old May 3, 2006 | 11:59 PM
WillieC's Avatar
WillieC
It sems to get easier as the bike gets some miles on it.
Old May 4, 2006 | 03:42 AM
TXSwede's Avatar
TXSwede
Or when the rider gets some miles on him. It'll get to be second nature in no time!
Old May 4, 2006 | 11:43 PM
06dynablack's Avatar
06dynablack
neutral real easy and going to neutral from 2nd real easy after the recall
Old May 5, 2006 | 01:07 AM
tarathatcher's Avatar
tarathatcher
Mine was a little tricky to find at first, but it's getting easier as I ride the bike
Old May 5, 2006 | 09:53 PM
davidchristopher's Avatar
davidchristopher
I went to the dealer and asked him about it. He said if it was still hard after around 1000 miles to bring it in, but that it IS normal- he said "everything is really tight at first, it'll loosen up". As soon as he said that, the Bobber started letting me put it in neutral at idle. I had not ridden since I posted it it, so either the bike is psychically linked to Harley Davidson Toronto or it reads the forums.
If figure the bike reads these forums. That's what I figure.
Old May 6, 2006 | 04:24 AM
phreak's Avatar
phreak
ORIGINAL: davidchristopher
Sounds like she has a miond of her own. Name her Christine
Old May 6, 2006 | 04:27 AM
anubisss's Avatar
anubisss
Just change the oil at a thousand miles and get used to having the right touch to get it into neutral. It's kinda like getting used to a different woman.Name:  efd65180.jpg
Old May 10, 2006 | 12:19 AM
glidester's Avatar
glidester
6th Gear
Default RE:had same problem ( neutral )
MY 03 Superglide Sport was a little hard to get into neutral too when it was new. But after the first check the problem seemed to work itself out. Had a little trouble with the neutral switch but that was just for the indicator light. If it keeps up get it checked.
Keep the rubber side down.
Glidester. Newfounland Canada.
Old May 10, 2006 | 12:21 AM
glidester's Avatar
glidester
6th Gear
Hey Whiff
What exactly did they do to yours to fix the problem?
Glidester
