Sears Red Cycle Jack
Sorry to throw at you guys, I bought the Sears Red floor jack (what exactly do I need for the adapters to fit my 07 FXD.............Thanks for all the help. Or any other suggestions
One corner of the frame is lower than the other three. Lifting your bike without something to compensate for the difference will cause it to be unstable. The adapters don't make it any more stable. I can't stand them. They've seperated on me before while the bike was on the jack. Not good.
I have had no problem using the adapter. You can get them on ebay or from your dealer. I would go the ebay route.
http://cgi.ebay.com/ebaymotors/lift-...Q5fAccessories
just a 2x4 under the primary and your fine... strap it and your golden... i have had prob 40 bikes up and down on mine with no issues. just take your time and strap EVERY TIME! EVERY ONE!... no matter how solid they are.
I've got the same jack and the HD dyna frame adapters and they both work just fine for my purposes. I can get my bike on and off the lift with no help from anyone else. It's pretty stable but always use straps just in case.
I've got the Sears yellow jack and use the HD adapters also. They seemed kinda tricky at first but after the first time I used them it is easy to put them under the bike and roll the jack under the bike and start jacking it up while I sit on it. After the jack makes contact with the bike and raises it slightly I get off the bike and jack it up the rest of the way.
Mike
bobbyd3
Aug 6, 2007 09:01 AM
commander112
Jul 12, 2007 05:48 AM
