anyone have trouble with system relay?
Old Jan 10, 2017 | 10:11 AM
  #41
cowboybob56's Avatar
cowboybob56
Originally Posted by NORTY FLATZ
Avoid getting water near your box. And don't use compressed air to blow water into the box deeper!
Using di-electric grease is a good idea. I use it on the spark plug caps too.
Great advice. Thanks for the reply.
Old Jan 26, 2020 | 12:03 PM
  #42
Paula Jeanette Schwartz's Avatar
Stage III
Default Diagnostics trouble
I have an 06 dyna low rider setting P0261, P0263, & P1003 codes. From everything I've found online it sounded like I needed to replace the system relay, so I did & it didn't help. My ground cable s & other connections seem to be tight & I haven't found any corrosion anywhere. Anyone have & thoughts on this?
Old Jan 26, 2020 | 06:12 PM
  #43
seniorsuperglideE8's Avatar
seniorsuperglideE8
For what it's worth, when I wired helms stations for boat company and the relays we used were of Bosch origin. Anyway there were black 12v relays and gray ones . The gray ones had a diode in the relay to the internal switch, that may be the case with HD's start and system relays.
Old Jan 26, 2020 | 06:17 PM
  #44
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Active Streak: 30 Days
That relay is pretty reliable. More then likely, battery or its its connection. Is your fuse box clean and free from corrosion?
Old May 6, 2020 | 09:06 AM
  #45
ecknearpittsburgh's Avatar
ecknearpittsburgh
Stage I
Same problem for me multiple times, system relay each time. But the first time I used electrical contact cleaner then put dielectric grease on the relay contacts. When you turn the ignition switch you should hear the fuel pump whine.
Old May 10, 2022 | 04:14 PM
  #46
LiveWireSteel's Avatar
LiveWireSteel
Stage I
Default Was that the underlying issue? Dealing with a basket case that three other hands touched.
Originally Posted by kdawgmfic
The system relay is the black one, the gray is the starter relay. Mine went bad and took a week to get one in. I just took it off and bench tested it. After finding that it was still operating, I took it apart and freed up the switch, spraped the contacts and all was good. The cover got beat up a little takin' it apart, but when I was done inside, just put a little tape. If it is bad, it can be intermittent. The contacts on mine were corroded pretty bad. Sometimes they would make contact, sometimes not. The grey starter relay has one more terminal on it but will plug right up where the black one is. I did this on mine in the begining stages of diagnosing my problem and all was well. DTC codes P1001, P1002, P1003, P1004. Any of them codes leads you to the System Relay.
m
Howard Richman
Mar 27, 2014 06:32 AM
TennesseeMustangPerf
Oct 23, 2011 05:59 PM
LINZ FDXF
Oct 19, 2011 06:26 PM
robertj74
Jul 30, 2009 07:02 PM
budder
Jul 9, 2007 09:57 AM
