Checking my Dyna's oil
Guys:
I glance at the oil dipstick before almost everytime I ride. Me thinks: Ok it's there and it's not too dirty is my general impression. (I get it changed every 2500). Just making sure it didnt all leak out or evaporate or something. LOL
But HOW do I do it correctly? You know, perform a perfect oil check. Never bothered to figure that one out. Bike straight up and down or leaning on jiffy stand? Bike hot or cold? Screw the dipstick in all the way in or not? Wipe it off, redip it and where should it be on the stick? Hellifiknow!
Any help would be appreciated.
Tony
Tony
My bikes a 2000 and back then you check the oil when it is on the jiffy stand. Also it should be checked after the bike is warmed up.
Pull the dipstick out, wipe it off, push it back in till it seats, pull it out and check the oil level.
Guys:
Tony
Tony
Received 4,332 Likes
With my pipes it just makes sense to check it cold,for safety sake man those burn scars last a long time! ouch!! sitting on the on the jiffy, leave enough time for all oil to drip into the pan (2 minutes max) wipe the dipstic screw it all the way back down and out. cold level anywhere above half the squares but not over the last square. hot it should be right at the top line. You are still safe to ride as long as there is oil on the dipstick when cold,but i would never push my luck with that.I change mine after every 3000 miles and never have to add oil. sure some is gone but it's ok.
