Forward Controls & Neutral
Old Sep 27, 2009 | 11:49 PM
JimmieJack's Avatar
JimmieJack
Default Forward Controls & Neutral
I put HD forward controls on the 09 SB. I decided to go the "quick" route and not pull the primary. I also left in the mid shifter shaft. I'm okay with the look and I didn't really want to cut the shaft until I was sure I liked the forwards.
So far I've only had a chance to test ride it. It was a little hard to find neutral but its there (somewhere). I heard the longer gear shifter in the forward kit will help out with the neutral.
The Question(s) - Does the longer shifter help? Can the longer gear shifter be install without pulling the primary? It looks like there may be a little room to "work it" but I don't want to start prying and banging on things if it can't be done.
Old Sep 28, 2009 | 04:36 AM
scott_db's Avatar
scott_db
The longer arm helped my wife on her 06 dyna and it can be replaced without taking off the primary. There is a couple of threads here about it, this is a good place to start forward-controls-now-i-cant-find-neutral-2
Old Sep 28, 2009 | 08:27 AM
Sonny's World's Avatar
Sonny's World
This is not the first time I've heard of the elusive neutral situation. Personally, I haven't had any difficulty finding mine since making the switch to forward controls though. Lovin' the forwards.
Old Sep 28, 2009 | 05:59 PM
Prodriverdon's Avatar
Prodriverdon
Get rid of the stock tootsie roll shifter and buy a longer one and finding gears wont be a hassle.
Old Sep 29, 2009 | 12:05 AM
09B29's Avatar
09B29
I tried to change mine out
no luck
there aint no way on a 07 fxd it can be done without pulling it all apart
I will live with this neutral problem till i pull it all apart
Old Sep 29, 2009 | 12:12 AM
JimmieJack's Avatar
JimmieJack
Thanks for the reply's - I think I'll leave it alone for now and see how it goes.
Later (couple of weeks) I'm going to change out the primary cover to polished aluminum so I think I'll have to remove the mid shifter shaft then and decide on the gear shifter.
Otherwise the forwards feel pretty good - they are a little more forward then they were on my sportster but I'm adjusting (all part of the process).
Old Sep 29, 2009 | 03:18 AM
Trawfish's Avatar
Trawfish
You could put a second hole lower in the front shifter arm to reduce the ratio/leverage. If you dont like it, put the shift rod back in the top hole and and revisit removing the primary.
Old Sep 29, 2009 | 03:47 AM
scott_db's Avatar
scott_db
no luck
I don't believe that there is any difference in the setup of the shift linkage and primary between a 06 and 07 fxd. I felt the same sitting on the ground in my drive way and decided to could not be done. But I went back and read the post here and told myself if they can do it I can. Give it another try after reading all the post that were provided for you. Good luck.
Old Sep 29, 2009 | 06:56 AM
dyna07custom's Avatar
dyna07custom
I have no problem finding N but I used the kury kit
Old Sep 29, 2009 | 07:01 AM
jcopel's Avatar
jcopel
Wow - I was just about to ask if anyone was using the Kuryaken Forwards out here and if this was a problem. Thanks man. They are a little more expensive than the HDs, but looking at the instruction sheets, they don't mention anything about replacing that back lever. I have heard that they are better quality than the HDs, also. Does anyone else have experience with the Krury's?
