West Coast T-bars install?
Old Feb 21, 2010 | 03:47 PM
JoeBobber's Avatar
JoeBobber
Default West Coast T-bars install?
Hello all,
I'm gathering parts for a wide glide conversion on my street bob, and probably going to switch to some 12 or 14 inch WC T-bars. My question is will i need to extend my cables with either of these bars being internally wired, and if so how much length will i need.
Thanks,
Joe
Old Feb 21, 2010 | 04:29 PM
KYFATBOB's Avatar
KYFATBOB
Not sure if this helps, but when I changed out my factory bars to street slammers the factory cables worked fine.
Old Feb 21, 2010 | 06:06 PM
lhcstreetbob's Avatar
lhcstreetbob
i used west coast t bars on my street bob and the cables and wires fit fine..
Old Feb 21, 2010 | 06:09 PM
rounder's Avatar
rounder
I bet the cables and wires will work fine. On your bike your stock apes are a little wider than the t-bar. Also even though the apes are considered 10.5" tall, you also have riser height as well. The 12" T-bar should be very close to the same height as your current bars, although the end rise is higher(meaning the apes bend down more towards the end of the grip). You should have a couple of inches of play in the wiring and cables so your stock stuff should work with the 14" bars also. Personally I would get the bars and install. If you can use all the cables, great, If you need a little more length, then buy what you might need. For instance all cables and wires may work except the clutch or something like that.
BullyDog's Avatar
BullyDog
As far as I know and have seen, stock should work. You may need to just tug a little excess out.
Old Feb 22, 2010 | 10:21 AM
JoeBobber's Avatar
JoeBobber
Thanks guys appreciate all the info.
Old Mar 16, 2010 | 05:30 PM
JoeBobber's Avatar
JoeBobber
can someone tell me what size riser bolts i should use with these bars. i just got them in and need to go grab a pair to mount them. I don't have any existing bolts as i just changed out the integrated risers on my street bob.
thanks
Old Mar 16, 2010 | 05:36 PM
RoadShark's Avatar
RoadShark
Wires and cables will be fine.......I have west coast 14's and they measure 15" from the base to the center of the bar.
Bolts I got at the stealer along with my poly busings........size I dont remember but they charged me like 4 bux for both bolts.
MS
Old Mar 17, 2010 | 08:34 AM
JoeBobber's Avatar
JoeBobber
Anyone else know what size bolt they used in the risers. can't get to the dealer till saturday, and would love to get this done before then.
Thanks
Old Mar 17, 2010 | 10:23 AM
HOGRIDA_06's Avatar
HOGRIDA_06
1/2-13 x 2 3/4 Hex Head Grade 5. As listed in my 2006 Parts catalog.
