Brake Light Switch ughhhh
Ok, searched and read many a posts.....I'm a victim of not protecting the front brake light switch in the housing. What are some things that can be placed....and where (in front of the switch button thingy???) should said items be placed? All future garage mechanics take note! $60 bones for a new front brake light switch! I swapped handles last year and NO problems, not so lucky this go around. Thanks for the help guys.
The pin on the lever (see image 1 p/n 1) pushes the plunger into the brake cylinder when squeezed... at the same time the brake switch which is mounted through the hole (image 2 p/n 3) is being released.
Now when you want to take off the lever from the handlebar and insert a piece of 4mm cardboard, the lever is pulled in alittle allowing the pin to come off the brake switch's rubber cap. Now the lever can be removed without snagging this rubber cap.
When you re-install the lever, insert the cardboard as well and insert the lever as shown in image 3....
FXD2003Rider
I had to replace my front brake lever and while I was paying attention, I still managed to snag the little button, break it off, and rip the boot. What you have to do to fix it if you dont' want to pay the $60 for the new switch and then another 45 mins of shop time is to take the master cylinder off of the handlebars, and take a small wood screw like 1/4" long and screw it into the hole that's in the end of the plastic plunger. All you have to do is have something that will stick out just a little bit to keep the plunger pushed in when the brake lever is fully released. I read other posts where people glued a piece of credit card on the edge of the brake lever so that will contact the plunger, others got a 1/4" set screw and used that, others put a glob of RTV sealant and put that on their brake lever to make contact with the plunger.
Hope this is what you were looking for
Christian
Christian
i smoked mine a couple years ago and it seems like it was only about 20 bucks. it was a bit of a challange to get the wires back in. a good tip would be to take a pic with the digital camera and then fold the wires just like they came out. either way, it was really not a big deal. you will remember next time. good luck.
scott
scott
Christian
