How to prevent TORX screws being stripped
Old May 8, 2010 | 12:13 AM
RandyDowdy's Avatar
RandyDowdy
Originally Posted by CRZYLGZZ
in case someone is wondering WTF an Allenhead cap screw is...
TheDone.... ya got a few pics of what your ride looks like with these caps. this is a good idea. I think im gonna go in this direction. Just wanted t get an idea of what im looking at.
I hope that anyone who as much as changes their own oil or plugs know what an allen head is!
Old May 8, 2010 | 02:17 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Didn't read all posts, but if someone hasn't said it already, before trying to break them loose, find a thin-nose center punch, put it into the recess of the head, and give it one good shot with a 32-oz ballpeen...seems to make them break loose like butter for me.
Old May 8, 2010 | 08:22 AM
Taddeoeg's Avatar
Taddeoeg
Originally Posted by Eddie A.
So, I'm a little confused . Can I use a Torx Plus bit in a regular Torx head screw? And, since I have a 2010 Fat Bob, are all the screws Torx Plus. How can I tell?
Yes, you have TP. No, you can't use a TP in a T - won't fit. You CAN but should NOT use a T in a TP - that's what causes cam out.
Get a set of TP and always try them first. If they fit, you're good to go. If they don't you found a regular Torx, although I don't believe you'll have any of those on your bike.
Old May 11, 2010 | 03:26 PM
ynots's Avatar
ynots
I'm glad that I stumbled across this tread before i went and bought a set of standard torx for my 2010.
What size should I go up to on a torx plus set.... t50, t55, t-60? What size of Allen (hex key) set to go to also much appreciated
Old May 11, 2010 | 05:55 PM
Taddeoeg's Avatar
Taddeoeg
The bolts that hold the fender on my 07 are 45. Can't say for sure but would assume they're the same on your newer model. I believe most sets go up to 50 so you should be good with that. Your choices are going to be limited anyway so get a decent set and then worry about buying the super big sizes only when and if you find a need for them.
Dynamite17
Jun 10, 2014 05:46 AM
FLHTCU Owner
Feb 2, 2012 11:20 PM
52edub
Jun 23, 2010 07:08 PM
dFREDb
Dec 4, 2008 09:07 PM
petemac
Sep 8, 2006 01:54 PM
