Remove the FUEL TANK to replace a HEADLIGHT?!?! Are they serious?
like bbreck said, just remove the tank bolts and slide it back. ORR just remove the front bolt and loosen the rear and slide a block between the tank and the top of the frame. Harness is in the frame under the neck.
I cheated and cut/soldered/heat-shrinked my wires.... best way is to do it the right way (not cutting wires)... but all my connections are in the bucket and sealed well so I think I'm 'aight.
What's the big deal? Pulling the tank is a breeze. $1.25 worth of fuel line and $2 for some good hose clamps (the 360 degree types) at AutoZone. Two vise grips and a cut in between and the crossover is gone. QD and two bolts and the tank is off.
Not really necessary to swap headlights but it does make it easier to access the wiring and prevents accidentally dropping tools on the paint.
None of that is necessary. When I changed my light I took the connector in the bucket apart slid the light off of the wires and when I got the new light on I put the connector back together and used it instead of the one that came with the light.
