Passenger Pegs for V&H Pipes on FXDF
Old 06-14-2010, 01:53 AM
dnebout's Avatar
dnebout
dnebout is offline
Default Passenger Pegs for V&H Pipes on FXDF
Looking at the Vance and Hines site for my Fat Bob, I noticed that the passenger foot pegs may not work with the following pipes:
Big Radius 2 into 2
Big Shots Staggered
Short Shots Staggered
These pipes look great but useless to me if there aren't any footpegs for my wife.
Old 06-14-2010, 02:03 AM
Cowpokey's Avatar
Cowpokey
Cowpokey is offline
Probly just need to put a block between the peg mount and swing arm, to raise the peg up a little. I've seen it mentioned to get those pipes to work on other models.
Old 06-14-2010, 07:59 AM
FATBOB-08's Avatar
FATBOB-08
FATBOB-08 is offline
Can only speak on the short shot's, no mods required.
Old 06-14-2010, 08:46 AM
Cowpokey's Avatar
Cowpokey
Cowpokey is offline
Other pipes come up higher than Short Shots, that's the problem the way I understand it.
Old 06-14-2010, 09:03 AM
FATBOB-08's Avatar
FATBOB-08
They were on his list, that's why I let him know that the short shots did not have a problem with the passenger pegs.
Old 06-14-2010, 09:10 AM
Splandman's Avatar
Splandman
Splandman is offline
I have big radius on my Fat Bob. No problem with the passenger pegs at all.
Old 06-14-2010, 09:12 AM
CRZYLGZZ's Avatar
CRZYLGZZ
CRZYLGZZ is offline
HD is nothing more than a simple puzzle to analyze. All things can be accomplished with a lil forethought, some basic tools, and a a few well placed questions on this Forum.
Im almost sure, Vance and Hines, took the fit into consideration and may well have a solution for the passenger peg issue.
I cant imagine them making pipes and removing basic stock components from the bike. especially safety items like the foot pegs.
If your still confused, give em a call first.
if not,do what i do, run a search on this board for those specific pipes and see what turns up. im sure someone turned a negative into a positive if that be the case.
Old 06-14-2010, 09:40 AM
Cowpokey's Avatar
Cowpokey
Cowpokey is offline
Understood, no worries...Only commenting on* what I've read on the others. Put the Short Shots on mine before the rear pegs and pillion.
*Edit add from there
Old 06-14-2010, 09:54 AM
FATBOB-08's Avatar
FATBOB-08
It's all good. I surprised V&H said that there may be a problem with the short shots, plenty of clearance. I guess if you increased the stock shock length you may run into problem but that would be the only way i see.
Old 06-14-2010, 09:57 AM
dnebout's Avatar
dnebout
dnebout is offline
Does your passenger feel the exhaust since the pipes are exiting right where the pegs are?
Quick Reply: Passenger Pegs for V&H Pipes on FXDF
